Hi!
Long time lurker, first time poster.
Thanks to everyone for creating such an killer resource - I've found so much information to save time and money here it's incredible.
My Audi is a 2008 S-Line 3.2 A6, bought at 62k from 1 PO, now at 93k.
Dealer serviced until 80k when I started getting serious about working on cars.
1 neglected oil change (9300 miles between).
My other car is a 1969 Toyota FJ40 expedition truck with a swapped in performance-IP'd Mercedes OM606 (1998) BiTurbodiesel (Custom compound turbos) that makes it roll forward. I did the engine swap, turbo system design, and everything else in my driveway, in the Oregon rain.
I say this only to emphasize that I have NO idea what I'm doing working on my beloved A6, and honestly little idea working on my truck (no sweet indoor shop, just a dream and a deadline) - it was all done based on conversations with fellow enthusiasts (nutbars?) and giving stuff a try - but I'm willing to get greasy!
I'm excited to enter the world of the ComputerCar, RossTech in hand. I am a systems designer for my day job; Familiar with our future robot overlords and how to listen to them.
So hat in hand, I come to the Forum with a Dreaded Rattle. I have searched, and searched, and if I missed something please point it out to me - you can even use all caps. I'll take it.
Read/watched LOTS on audi rattles, timing chain scariness to keep me up a night, but nothing that quite fits. Here is what I have:
- It occurs ONLY on acceleration, and varies in volume with the load on the engine.
- You CANNOT make the noise in neutral. Vroomyvroom vroomy vroooooooooom... People look at me, I'm just trying to perform Stoplight Diagnostics...
- It is a tdicktdicktdicktdicktdicktdicktdick as if you stick your tongue against your top teeth and make a tdicktdicktdicktdicktdicktdicktdick noise. I'm trying to get a recording, it's not as easy as I'd hoped....
- It is intermittent but in phases: Drive a few dozen miles, hearing it a little. Then it gets worse for a while, then better.
- It occurs between 1.5k and 3.5k rpm depending on gear.
- It does not affect power.
- It does not seem to become louder with the windows down (if anything, it's harder to hear).
- It does not appear to increase in tempo with RPM, but I have a hard time saying that with total certainty.
Also:
The engine is NOT throwing codes that I have read would be consistent with serious timing chain stretch. (Cam position sensors, etc).
It does occasionally (monthly) throw a code for a small evap leak, and an intermittently stuck intake flap/vane/thing.
Sorry, can't remember the codes, happy to supply if relevant.
As a result of seeing those codes, I followed AudiBug's wonderful DIY thread on carbon buildup inspection. Ta da! I have carbon buildup! Gaskets and supplies to remedy on the way...
I have run the test with the RossTech for the knock sensors. Both fore and aft are functioning, none are hitting what I understand to be the 12 degree limit. 7, however, is not unusual on some cylinders.
I recently did the Transmission Fluid Swap of Misery. Blauparts kit, whole nine yards. What a vomitously ornate process, especially leveling without a lift. Lifetime fluid *horrible swearing*. I think I bought it with the trans under-filled (CPO my *horrible swearing*) - shifts so much Mo'Betta now. On completion of this process, the Rattle abated for a while (50 miles of excited driving), then returned. I do not know/think this is necessarily related to cause, just trying to provide variables.
As a result, I am thinking:
-It is not detonation, since the knock sensors are active and not hitting limits. Maybe this is more hoping than thinking, but none of the codes would indicate detonation or mistiming. Cold starts are SLIGHTLY longer, but I'm using an aftermarket battery that's not the best (bought before I knew better, but working OK and I'll hang on to my 300 bones, thanks.)
- It is either an exhaust rattle (checked the heat shields all the way back, looked for other loose bits) or SOMETHING TERRIBLY WRONG WITH MY ENGINE, that is not detonation.
tl;dr - My engine makes a rattle when you push the skinny peddle but none of the normal (google documented) reasons check out so it's either something dumb and safe or something grim. Car in not an optional vehicle (DD).
Thoughts?
Thanks so much for reading all this - I can't afford to explode my car, your time is appreciated.
*gn
