A while back I changed my trans mount, then the next day replaced the brake cables (which involved dropping the prop shaft center support bearing to let the driveshaft sag and get the heat shield out of the way EDIT: just the bearing, the CV's stayed connected ).
I lined the center bearing back up with the dirt marks so it should be aligned (?), but ever since then I get this noise. Maybe the trans moved sideways somewhat when I did the mount?
- in first and second, between 1500 - 3000 or so
- if you go fast it is louder and sounds like a big turbo spooling
- if you go slow it's a fainter gear whine kinda sound, that holds if you hold the revs at say 2000.
- entirely absent by third.
ideas?
