Results 1 to 5 of 5
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    Brake pad wear sensor
    I've seen a fix where people splice a wire on a green jumper internally but don't think I want to be modifying in there. What would be an easy fix to eliminate the wear light? Should I splice and join the wires down near the sensor in the wheel well? Curious to know what you guys have done, my new pads do not account for sensors. Thanks in advance!
    "Brake last, finish first."
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    Do you have the plugs from the old sensors? Use them and solder or crimp the wires.
    Oct 14 2009
    AZ/NY
    Quote Originally Posted by 65vetteC6 View Post
    I'd have to check, you wouldn't happen to have a pair lying around would you?
    Jul 28 2007
    V8's
    In an Audi
    Quote Originally Posted by NYC_Legacy View Post
    I don't sorry. Any b6/b7 brake pad plug will work though.
    Veteran Member Four Rings MattboyR32's Avatar
    Nov 28 2006
    Orange County, CA, USA
    I did the internal mod. Works perfectly.
    B7 RS4 6MT Daytona Grey
    JHM 2.75" catback non-res, piggie pipes, 034 transmission, engine mounts, strut mounts & end links, Apikol diff mount, Hotchkis adjustable rsb, Escort 9500i (HW), JHM lightweight rotors, JHM intake manifold spacers, BC Racing coilovers,
    RIP: B7 S4 DTM 6MT Dolphin Grey
    JHM Tune, Corsa Catback, Piggie Pipes, Bilstein PSS9, RS4 Reps, Blackvue Car Blackbox (HW), Escort 9500i (HW)
