Results 1 to 22 of 22
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    2.0T - still misfires when colder
    Car is now (again) showing misfires on all 4 cylinders.
    Started to occur when morning temps dropped below 30 over the last 2 days.
    Recently done;
    - carbon build intake valves (VERY bad build up; misfires, barely starting)
    - PCV valve
    - new coils
    - new plugs
    - rear main seal
    Still has oil leak at timing cover.
    Unrelated: DSG service done.
    When car was brought to me today, it was warm, engine running and sounding perfect, no misfires. Yesterday, (not so) cold start, misfiring, CEL on.
    What else can I check and troubleshoot to determine the cause of the misfires?
    110k miles on the car.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Senior Member Two Rings mecg's Avatar
    Apr 12 2016
    Readfield, Maine, USA
    What are you getting for codes?
    2013 Audi A4 quattro Prem, ZF8, APR Stage 2+ 93/E85 Tune + Cast Downpipe/HFC, R8 coils, aFe Dry Pro, Eurocode Intercooler pipe, Turbo Muffler Delete, Fitch Fuel Catalyst, RS Grille, Tinted windows, Audi logo puddle lights, Interior LEDs, VCDS tweaks, 18x8 Andros R9 Wheels w/ Michelin Pilot Super Sports
    2008 Saab 9-5 2.3T BCB², K&N, Fitch Fuel Catalyst, Interior LEDs
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by mecg View Post
    Misfire random:
    000768 - Random/Multiple Cylinder Misfire Detected
    P0300 - 000 - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 7
    Reset counter: 255
    Mileage: 183529 km
    Time Indication: 0
    Date: 2019.14.19
    Time: 11:06:09
    Freeze Frame:
    RPM: 906 /min
    Load: 32.5 %
    Speed: 0.0 km/h
    Temperature: 6.0°C
    Temperature: 0.0°C
    Absolute Pres.: 980.0 mbar
    000769 - Cylinder 1
    P0301 - 000 - Misfire Detected - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 7
    Reset counter: 255
    Mileage: 183529 km
    Time Indication: 0
    Date: 2019.14.19
    Time: 11:06:09
    000771 - Cylinder 3
    P0303 - 000 - Misfire Detected - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 7
    Reset counter: 255
    Mileage: 183529 km
    Time Indication: 0
    Date: 2019.14.19
    Time: 11:06:20
    Freeze Frame:
    RPM: 900 /min
    Load: 32.5 %
    Speed: 0.0 km/h
    Temperature: 8.0°C
    Temperature: 0.0°C
    000772 - Cylinder 4
    P0304 - 000 - Misfire Detected - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 7
    Reset counter: 255
    Mileage: 183529 km
    Time Indication: 0
    Date: 2019.14.19
    Time: 11:06:20
    000770 - Cylinder 2
    P0302 - 000 - Misfire Detected - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 7
    Reset counter: 255
    Mileage: 183529 km
    Time Indication: 0
    Date: 2019.14.19
    Time: 11:06:20
    Freeze Frame:
    RPM: 900 /min
    Load: 32.5 %
    Speed: 0.0 km/h
    Temperature: 8.0°C
    Temperature: 0.0°C
    05 Golf TDI
    Active Member One Ring kehubbard's Avatar
    Feb 05 2017
    2012 Audi A4 2011 Honda Pilot
    Sycamore, IL USA
    Considering what has already been done it seems plausible that you should be looking for a fueling issue. Maybe the injectors are also nasty with carbon and can't flow enough when the engine is cold and in the enrichment mode.
    Oct 22 2017
    Fort Meade
    Just checking with u guys if u found the issue? I am getting the same exact codes. I have a 2009 A4 2.0t.
    Feb 20 2010
    Brighton, MI
    Update: through further searches, I found finally became aware of the carbon build up issue on the direct injected cars, specifically the Audi VW 4 cylinder 2.0T.
    Removed intake, and found intake valves CAKED with carbon build up.
    Cleaned.
    Running fine.
    Since then, have done several intake cleanings on 2.0T in my network who should symptoms, and as preventative maintenance.
    05 Golf TDI
    Oct 22 2017
    Fort Meade
    Good info. I know my rear main is leaking really bad. About how much did that run u?
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by chiefl View Post
    THAT (rear main seal leak) was another cause for misfire (2010 A5 2.0T). What mainly opened my eyes to that possibility was a leak test with a smoker (couldn't find anything from the top, but when getting underneath the car/engine, I found lots of smoke coming from transmission bell housing area); never thought of a rear main seal leak as a vacuum leak. Change rear main (shop around $1,500) fixed those misfires.
    Intake valve cleaning: what I read, around $400-$600 at shops.
    05 Golf TDI
    Oct 22 2017
    Fort Meade
    Interesting. Thx
    Established Member Two Rings Nczcar01's Avatar
    Jul 30 2017
    Conyers, GA
    I have heard some stories about upgraded PCV due to older versions causing rear main seal to blow....resulting in misfires.
    2010 Audi A4 Quattro 2.0L 6 sp mt
    2022 Ford F-150 Platinum 3.5L
    2024 Acura MDX
    2024 Mazda CX-90
    1994 Honda ST1100
    Oct 22 2017
    Fort Meade
    Ok interesting. I was planning on changing the pvc just as a precaution for future problems. Taking the car to a shop tomorrow to get the rear main done.
    Oct 22 2017
    Fort Meade
    Just an update
    I had the RMS done and changed the PVC to include an intake valve cleaning. The car how ever continues to have a misfire in cyl 2&4. The shop is keeping it over the weekend to do a smoke test. Hopefully its something minor. Im done throwing money at this car
    Oct 22 2017
    Fort Meade
    So for the RMS-$1600
    Valve cleaning-$500
    Smoke test-$200
    Feb 20 2010
    Brighton, MI
    Just to be sure, you already did check the obvious: coils and plugs?
    If you have vagcom, watch block 015 and 016 (misfire counter per cylinder).
    If predominantly 2 and 4, switch coil 2 to 1, 1 to 2. Repeat and check misfire count.
    Then plugs.
    With cleaned valves, rear main seal and no leaks (smoke test), PCV done: not sure where else to look really.
    I assume misfires when when cold and idle? And not so much when warmed up, and driving?
    05 Golf TDI
    Oct 22 2017
    Fort Meade
    Coils and plugs r brand new from ECStuning. Lets see what smoke test results r. They already swapped coils and that didnt change. Last things i can think of is the manifold or the injectors.
    Oct 26 2017
    Toronto, Ontario
    Sounds like injectors.
    Sent from my SM-G935W8 using Tapatalk
    Oct 22 2017
    Fort Meade
    Shop did a compression test and got 90 psi from cyl 2 & 4.
    Jul 30 2017
    Conyers, GA
    Check this thread out. Sounds like some similarities.
    http://www.audizine.com/forum/showth...mpression+test
    2024 Acura MDX
    2024 Mazda CX-90
    1994 Honda ST1100
    Oct 22 2017
    Fort Meade
    It does. Might be worth a look in the valve cover.
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    Its most likely your injectors. i was having the same issue. Missfires on cold starts, then runs fine after being warmed up. Swapped injectors, problem gone.
    Oct 22 2017
    Fort Meade
    Dont see what injectors have to do with low compression??
    Feb 13 2004
    Lakewood, CA
    ^^^ i was responding to the OP issues not yours. sorry for confusion.
