Results 1 to 3 of 3
    Junior Member Two Rings
    Aug 08 2016
    ohio
    did an oil change this weekend with one issue.
    So I did an oil and filter change this weekend. I'm starting to do them every 7500 miles now that I have the APR stage 1 tune. Only problem I had was getting the drain plug for the oil filter loose. I used a 6mm hex to loosen the filter drain but it would not turn and I started to strip it. I decided to just loosen the filter housing with a 32mm socket and got the filter out. Little more mess but no big deal. Only concern is that I believe there is a rubber gasket for the drain plug that I did not replace.
    2013 S6 estoril blue
    Previous: 07 A8L
    01 allroad
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Is this your first time doing the oil change on the car? Whoever did the last one vastly over tightened the drain plug. Fix it next time while the filter housing is off. You may need a replacement housing if you cannot get it out. $70 The small o-ring will last till the next change.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Aug 08 2016
    ohio
    got another filter housing ordered ($55 ecstuning). Will put it on next oil change in 7500 miles. very easy oil change in fact the most time consuming this was removing the 18 or so screws to get the under body cover off. I had the front end jacked up and let it drain for an hour. I took exactly 8.8 quarts to fill it full just as the manual states.
    Previous: 07 A8L
    01 allroad
