Results 1 to 3 of 3
    Established Member Two Rings Mussa's Avatar
    Oct 31 2015
    Istanbul - Turkey
    -10.5 degree Timing Pull. Is this normal?
    I took a log for a timing pull @ 3rd and 4th gear from 2000 to 6150 rpm WOT.
    As seen basically in the graph for 4 of the cylinders timing pulls were 0 for all the rpm range. However at 6100 rpm for 3 of the cylinders -10.5 degrees of timing retardation occured. At that time the specified/actual boost was 530/1645 hPa.
    Should I be worried about this?
    2011 A4 B8 2.0 TFSI Quattro S line S tronic // APR Stage 2 98 RON - OEM Dual Exhaust - OEM 3.0 TDI FMIC
    - USP HFC - RS4 Black Grille
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    That's because you hit the rev limiter that's preset in the ECU; therefore for engine protection, the ECU pulls timing.
    - Erik
    PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    Oct 31 2015
    Istanbul - Turkey
    Quote Originally Posted by bluefox280 View Post
    - Erik
    Hmm, but i've hit the red line a few times and no timing pulls occured. Only this one.
    Maybe it's about the boost, the actual boost exceeded the specified quite alot.
