Results 1 to 16 of 16
Thread: Boost Leak
    May 09 2012
    United States
    Unhappy Boost Leak
    Ok a little history,
    The car is an 01 6 speed. Just finished installing stage 3 parts (see below). and have the a tune from Blake Beadle, base stage 3. Started the car and had a very rough idle, running rich, and would die. So assuming there is a boost leak I unplugged the MAF and the car smoothed out and ran fine, albeit rich. So attempted to pressure test the system but I can build zero pressure. Cant hear any leaks and visually inspected the connections I could see. So now I have a smoke machine to hunt out the leak. Put smoke to the system and the only place smoke was getting out was from my exhaust. I am stumped, is one of the turbos (both maybe) fucked and the pressure is by passing the seals? or is a waste gate or check valve on the spider hoses stuck open. Any help is appreciated.
    RS4 K04's
    85mm MAF
    550cc Bosch EV 14 Injectors
    Bosch 044 Fuel Pump
    Wagner Sidemount Intercoolers
    APR Diverter Valves
    Cold Air Intake
    3" Downpipes
    3.5" Single Exhaust
    034 Bipipes
    Do a compression test check your timing test vacuum lines to wastegates
    Sent from my HTC331ZLVWPP using Audizine mobile app
    May 09 2012
    United States
    Dont have the means to currently do a compression test, timing is good as the car runs fine, and I will attempt to test the vacuum lines to the wastegates.
    However, how would these items effect a boost leak test from the y-pipe to the throttle body
    Senior Member Two Rings 616_S4's Avatar
    Mar 07 2016
    2001 S4
    Grand Rapids Michigan
    What do you mean build pressure? You don't build pressure in a boost leak test. You're simply putting through a certain amount of pressure through the system.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Quote Originally Posted by 616_S4 View Post
    This. You need an air compressor and a regulator. I just did mine and Hooked it up and pressurized to 20psi with continuous flow. Found a small leak with mine. You will hear it even if small.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    What do you mean you don't build pressure? What do you think a leak test does? You put 15psi through the intake it should slowly drop. If it won't build pressure, there's a massive leak.
    May 09 2012
    United States
    Ok, instead of running constant air on the system I built a similar system as the AWE DIY tester. Instead of an air line quick coupler I used a one way valve and attached a gauge after the supply air valve so I could put the desired amount of pressure to the system and use the gauge to see the amount of pressure in the system, and if it bleeds off I know there is a leak somewhere.
    I went this route because from what I understood was that the system from the intake to the throttle body is closed and should hold pressure.
    But from what I am reading that information was incorrect and the system is open so no air pressure would build
    May 09 2012
    United States
    Some pressure should build in the system though if there isnt a "major" leak. So thats what lead to a smoke test and the actually question of why am i looking pressure out of my exhaust
    Jan 14 2009
    pasadena md
    Well you are going to loose air into the cylinders because one or 2 of the cylinder will have the intake valves open. And If your looking it through the exhaust. Then either 1 of two things you have burnt exhaust valves or you have a little overlap in that cylinder and thats where its coming from. i would run a compression test.
    Aug 06 2016
    colorado
    Where are you putting the tester?
    Nov 05 2009
    Denver
    If it ran fine before the turbo swap I doubt he's looking at burnt valves. What MAF and what ecu/tune do you have? Forget your findings for a sec.
    Jan 14 2009
    pasadena md
    Quote Originally Posted by Zba View Post
    Sorry forgot about that. But did you put a Timing belt on when you did the stage 3 install. Also what are your fuel trims. Everything plugged back in correctly. Any cel's. Sounds like a case of something simple causing the issue. Is it missing on 1 cylinder. Also what is the vacuum reading at idle?
    Senior Member Two Rings AudiTuner1187's Avatar
    Jan 17 2014
    Delaware
    If you unplug MAF and it runs fine there's your problem. Something with that, maybe tuned for wrong one?
    Sent from my SM-G900V using Audizine mobile app
    Veteran Member Four Rings RocksForsSale's Avatar
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    Boost Leak
    Quote Originally Posted by baker1o7 View Post
    Get the cheapo c tester on amazon, works great. I did mine while swapping out plugs.
    Mar 07 2016
    2001 S4
    Quote Originally Posted by chaos2984 View Post
    Someone knows whats up, ive found that the smallest leaks are the loudest, Ive had a huge leak from a hose half off that i could only hear turning the pressure up a little because its a deeper note sound.
    What psi are you putting through?
    Sep 09 2014
    Grand Rapids, Michigan
    I'm sorry, but what? This thread is full of misinformation.
    If your car runs smooth after you unplug the MAF, skip the compression test/leakdown/wastegate lines. Waste of time. Motor is fine.
    A boost leak test will build pressure. Yeah, it will leak out slowly, but you should be able to sustain pressure for some time with no leaks.
    If your MAF is unplugged and the problem gets better, it is more than likely going to be a pressure/vacuum issue. MAF gets unplugged -> ECU goes blind -> ECU goes into an open loop A/F ratio -> car runs smoothly because it isn't constantly trying to adjust the ratio due to an unmetered air leak.
    If your car is dying out with the MAF plugged in, I guarantee its a massive leak at an inter cooler or at the throttle body boot.
    Edit: You didn't see the smoke leak in your engine bay because a smoke test doesn't build pressure like a pressure test does. You'll have to do some more convincing to find that leak. zero pressure built = leak.
