Hello, so I have recently begun working on a 2001 Audi S4 I purchased last year as a project. I feel there may be a lot more involved with this project than I originally anticipated, but I am confident with patience and time I can learn what I need to work through the individual issues.
My first question is can I get away with using a VAG-COM 11.11 cable and software copy like this?
https://www.bonanza.com/listings/Hex...FQuEaQodc_8Njg
Reason being,within the last month I have bought a truck and had a baby, and don't really want to spend $200 right now if not completely necessary. I was hoping this cheaper alternative could allow me to identify the source of multiple issues I'm experiencing.
So first off, I am receiving a flash CEL whenever I go WOT, along with stuttering usually only in 2nd gear and up. It sometimes does it in 1st gear as well. My original thought is potentially a boost leak, and I have ordered the components to do a pressure test, but was curious if anyone else might have insight? Also, my ABS and the triangle with a circle around it, both of those lights have come on, then go off... I have done some reading saying this could be tied into the MAF somehow? I was thinking a bad MAF could also cause a misfire, so maybe the two are linked? I also read a bit about the ABS module and potential dirty/bad wheel speed sensors. It's honestly hrd for me to pick the best place to start, so I figured I need to have at least SOME form of diagnostic software, so I could start monitoring things and hopefully eliminate issues and narrow it down a bit. I appreciate any feedback and advice, I would like to just get the Ross-tech eventually, I'd just rather not spend $200 right now if I don't really HAVE to. Any and all advice and feedback welcome, and thank you.
Sent from my SM-G930R4 using Audizine mobile app
