Results 1 to 3 of 3
    Established Member Two Rings SilverRings's Avatar
    Aug 20 2015
    Louisville, KY
    Differential Oil
    I've seen the write-ups. 75w90 GL-5 for the main gear oil. Then they say ~500mL of Audi Transfer Box oil. Comes in a 850mL bottle. Part number G052515A2. --What is this type of fluid? I'd like to get something different since the Audi kind is so expensive.
    2011 Audi S4 // P+ // Sport Diff // DSG
    EPL Stage 2 and TCU | AWE Touring Exhaust | 19x10 et42 Forgestar F14s | Ventus V12 255/35/19 | KW Street Comfort Coilovers | EuroCode Rear Sway Bar | EuroCode Trans/Diff Mount Inserts | EuroCode Alu Kreuz Driveline Stabilizer | CR15 Strut Tower Brace | StopTech SS Lines and Fluid | Akebono Euro Pads | Centric High Carbon Discs
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    I would just get the Audi oil just for the peace of mind, that diff is super expensive to replace.
    Established Member Two Rings Andrew Lane's Avatar
    Jan 03 2017
    2012 Acura MDX, 2014 Audi S4, 2010 Ram 1500 Laramie, 2009 SRT8 Challenger
    Thunder Bay, Ontario Canada
    Pretty sure that the other fluid is ATF for the control side of the sport diff from other posts that I have read. I don't have that diff though, so I can't say for sure! You should be able to find the correct oil and specs if you do some searching!
