Hi All,
It's time that I sell my Audi. This is a very fast and fun car to drive. I'm the original owner, non-smoker, and the car is kept in my heated garage on a CTEK battery charger. All work performed was completed by Prestige Imports, Peak Eurosport, and 3R Racing. I have the title and all paper work in hand. I'm a mechanical engineer by background so I'm pretty detailed and organized.
This might be one of the only cars that has the Brembo GT-R big brake kit. This was a $15K brake kit (not including install cost). It's the GT-R, not just the GT.
I have the car listed for sale on eBay. The auction ENDS this Wednesday, March 8th at 4:54 PM. The car just itself as stock would be worth $30K. Here is a link.
http://www.ebay.com/itm/2011-Audi-S4...NYs1p4&vxp=mtr
I'm new to the AudiZine website, so bare with me on my response time with any questions as I figure out how the forums work.
Below is the Build List:
Mark
2011 Audi S4 quattro – Prestige
3.0 TFSI DOHC super charged 6-cylinder engine with dual intercoolers and FSI Direct Injection
Seven-speed, dual clutch, S-tronic transmission with Quattro all-wheel drive
Ibis White Exterior
Black Interior
Factory Options:
Prestige Package
Audi Drive Select with Sports Differential
Silk Nappa Leather Seats
Carbon Atlas Inlays
Super Charger Badge
Front License Plate Holder
Dealer Options:
Clear Mask
Window Tint
Cargo Mat
Audi Sunshield
Two (2) Carbon “Truth in Engineering” license plate frames
Performance Modifications:
Engine:
APR Supercharger Pulley Upgrade with Stage II+ ECU tune
APR Coolant Performance System with Separator, Pump, Radiator, and ADS auxiliary cooler
Engine Oil - Motul 300V Power 5W-40
Intake:
APR Carbonio Carbon Fiber Cold Air Intake System Stage I & II
Exhaust:
Eurocode Long Tube Headers
Thermal R&D (Stasis) DSG Cat back exhaust
Stratosphere mini-cat O2 spacers
High Flow 200 cell catalytic converters with flanges and V-bank clamps
Test pipes with flanges for swapping out catalytic converters
Suspension:
Ohlins shocks with Eibach springs (Stasis) with KW Automotive cancellation kit
Eurocode Front Adjustable Sway Bar
Eurocode Front USS Billet Aluminum Adjustable End Links
SPC Front Adjustable Control Arms
Eurocode Alu Kreuz Billet Aluminum Drivetrain Stabilizer
Eurocode Rear Adjustable Sway Bar
Eurocode Rear USS Billet Aluminum End Links
Alignment: Negative 2 degrees and zero toe in rear, Negative 2.0 degrees front (Front can go to -3 degrees or more)
Corner Balance: 50/50 cross corner balance with driver weight, no spare tire, and quarter tank of fuel.
Brakes:
Front - Brembo GT-R six piston calipers with crossed drilled, 380mm x 32mm rotors
Rear - Brembo GT-R four piston calipers with crossed drilled, 380mm x 28mm rotors
Pads – Forodo FM1000
Brake Fluid – Motul RBF600
Wheels:
HRE P44SC wheels, 20 x 9.5, et=39, high offset, tinted clear brushed finish, 112x5 bolt pattern for use with stock wheel bolts. Wheel weight = 23.5 lbs.
Tires:
Michelin Pilot Super Sport, 265/30/ZR20
Exterior Trim:
Deval Front Carbon Lip
Deval Rear Carbon Valence
Interior Trim:
K40 RL360 with EX2 Laser Diffuser Radar Detection System. Laser Diffusers mount in Front Grille.
P3 Cars Vent Integrated Digital Interface
AWE Tuning Boost Tap
RS5 petals
S-Tronic Shift Knob
2.5 lb Stainless Steel Halon Fire Extinguisher mounted in Brey-Krause QR Mount
