Wondering if you can help me out here. So, last week I had a 'Final Destination' moment driving to Subway and was nearly T-boned when my Audi suddenly lost power. To me it felt like the car was out of gas. The more I pumped on the gas pedal I would get small 'spurts' of movement (which saved me from getting hit at 45mph).
Anyhoo, I used what was left of the cars power to get it safely into a parking space. I shut it off and tried to start it up. It would start up and die after about a second. Assuming my gas gauge had broken I walked to a nearby gas station for a gallon and filled her up. This time, the car started for a bit longer but the idle was really, really rough. I mean it would surge up and down and eventually drop low to the point the whole car would shake like crazy. Since I couldn't drive it in this condition I called for a tow and got it towed over to the Audi dealership for a diagnostic.
After a few days in the shop I get call from the dealership saying that 'We have checked everything and cylinders 1 & 3 are bad. There is an internal valve issue. And your catalytic convertor needs to be changed which could be adding to the problem.'
The services rep then mentioned 'the engine is not worth fixing' and proceeded to quote me $6,000 for a new engine install and Catalytic convertor.
Is this normal? Do cars suddenly just lose compression and valves get damaged to the point of no return? Am I getting bamboozled by the dealership? Did the techs actually open my engine up and see bent valves?
I was also told the timing and belt are fine. Water pump was changed by previous owner four months ago. I recently did an oil change and flushed the coolant (with the right kind) and changed all control arms myself and got an alignment. I have since put on about 100 miles. I have put about 300 miles on it total since buying it in December and am not sure what to do since $6k for an engine is rediculous..
