Results 1 to 18 of 18
    Veteran Member Three Rings eightamrock's Avatar
    Jan 21 2016
    ECS RS4 mesh gille question.
    Bought this grille from ecs. Can anyone tell me what those mounts are for? I assume parking/drive assist sensors which I don't have. I think I could cut them out, was hoping to hear if anyone had done this already or had tips.
    '19 Daytona Gray RS5 Sportback
    Options: B&O Sound, Dynamic, Navigation, Black Optic, RS Driver Assist, RS Stitching
    Mods: Suntek PPF wrap
    Nov 08 2015
    Newtown sq, Pennsylvania
    Yes they are parking sensors, mine were hot glued on. I just wiggled mine loose.
    2016 Glacier White S4 P+
    6MT | Black/Magna Nappa Leather | Tech Package | Carbon Inlays | Sport Diff | Alu-Optics | Black Optics | B&O | LED Interior Lights |
    25% Tint | LED Fogs | 19" BBS CS5 Winter Setup | Eurocode sways F+B | Eurocode endlinks F+B | Deval Diffuser+Front Lip | | ECS 10mm Spacers | USP Stainless clutch line | E-codes | ECS Diff mounts | Eurcode Tranny mount |
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    They just kinda wiggle off like said above.
    Jan 21 2016
    Quote Originally Posted by tar View Post
    Nice. Thank you both.
    Did either of you wrap your crash bar with vinyl or did you just paint it? Also curious if you put the foam back or left it off.
    Mar 21 2015
    Paint it, foam won't work with that
    Jul 07 2009
    Socal/IE
    Plastidipped mine. Plan go go with something more permanent soon tho. Running no foam
    Sent from my VS987 using Tapatalk
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Sep 11 2015
    2003%20VW%20Jetta%201.8T
    Western Mass
    No foam, plastidipped mine and has been good for over a year
    2015 Mythos Black Pearl BO 6MT S4 P+ | 19" peelers | Nav | Carbon inlays | B&O | Sport Diff | Nappa
    Mods: 20% tint | EPL | OEM Audi Sport plate frame | HOEN fogs |ECS 10/12.5mm Spacers | Hardwired radar | ECS Trans insert | CTS intake | AWE Touring Exhaust - stock DPs | H&R OE Sports + Koni Shocks | Eurocode F&R Sway
    Nov 08 2015
    No foam, painted mine with flat black spray paint I got from pep boys.
    Jan 21 2016
    Quote Originally Posted by hyetiko View Post
    Nice. Was thinking some rustoleum might do the trick.
    Nov 02 2015
    Orlando, FL
    paint will not hold up over time to rock chips. use something like truck bed liner.
    2018 Audi RS5 Coupe, 034 Motorsport ECU and TCU tune, 034 Motorsport Front Strut Brace, 034 Motorsport Transmission Mount Insert, Kohlefaser Luft-Technik Carbon Intake System, MercRacing Multi-Pass Dual-Core Heat Exchanger, Pierburg CWA100 Water Pump, Bull-X Resonator Delete Pipes, ORT Motorsport HPFP, Maxton V2 Front Splitter, Savini SV-F5 20x10 Wheels, Michelin Pilot Sport 4s 285/30/20 Tires, H&R OE Sport Springs (yet to be installed)
    Jun 06 2016
    Florida
    Or undercoating.
    2018 Daytona Gray S6 | S Sport | Black Optic | Carbon Atlas |
    2011 Phantom Black S4 | S-Tronic | P+ | Nav | Sports Differential | Titanium Package | Silk Nappa | SOLD
    Jan 11 2017
    Houston, TX - USA
    Might want to look into using black fine chicken wire and mounting it behind the RS grille, helps reduce the color of the crash bar against the intercooler and protects the intercooler. Some forum member makes them precut, I don't know if he still sells them, but it's not very hard to make and from what I hear, it's not hard to mount either. You just use the holes and screws you we're gonna use but add the mesh this time. For sure paint the crash bar though, looks terrible without it being painted especially with the holes of the RS grille
    Established Member Two Rings tjenne69's Avatar
    Oct 23 2016
    Washington, IL
    Used spray on bed liner on mine.
    2013 S4 Prestige Volcano Red | ESC Luft-Technik Intake | ESC X-Pipe | EPL Stage 1 +DSG | RS4 Grille
    Jan 21 2016
    Quote Originally Posted by tjenne69 View Post
    Where does one find this? Any auto parts store? I've so often called the sensible place to find something and the people act like I'm crazy and the product doesn't even exist. Lol....
    Oct 23 2016
    Washington, IL
    Quote Originally Posted by eightamrock View Post
    Yep. Got it at advance auto. I used Dupli-Color Bed Armor.
    Sent from my XT1585 using Audizine mobile app
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    Quote Originally Posted by chrisucf99 View Post
    so true. My crash bar is already in need of repainting after 1 year.
    Jan 21 2016
    Established Member Two Rings CraigAudiS4's Avatar
    Nov 16 2016
    Olney, Maryland
    I had mine painted black and left the foam on which was also painted black (I had a body shop install) and they recommended I keep the foam on, said it can make a big difference in an accident. They also painted my mirrors black. Going on a year and everything still looks good, I figure worst case I just touch up again.
    Not sure what kind of black paint they used on the foam as I know some kinds will literally melt foam. No issues on mine.
    2015 S4 Phantom Black with RS4 Grill, 19" stock Rims with Dunlop Signature HP Ultra High Performance All Season Tires, Painted Mirrors Black and still 100% stock Engine.
