Results 1 to 9 of 9
    Oct 28 2012
    near chicago
    magnaflow exhaust installation
    just picked up a used magnaflow exhaust. seemed a good compromise as (when watching the few video clips i could find) seemed quieter than the other alternatives but a little more aggressive than stock. I haven't even been under the car yet as I've moved shops and haven't yet set my car lift. I'm wondering in advance what will happen with the exhaust valves. I've read there are exhaust flaps in the tail pipe tips but wondering if installing an exhaust without them, and leaving the connectors hang, is going to throw a cel?I pulled up the install sheet on magnaflow and it make no mention of this.
    Veteran Member Four Rings 1975audi's Avatar
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    I was wondering the same thing.
    Going custom Magna flow mufflers
    2007 RS4
    2000 B5 S4 stage 3
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    I believe others have left it unconnected without issues and is only a one way connector meaning ECU sends the signal but the valve doesn't feed back any signals. A good test is disconnecting them now and seeing how it behaves with the stock exhaust. If no codes then no codes later.
    Senior Member Three Rings Cris_OO7's Avatar
    Jul 08 2010
    Woodhaven/NY
    AWE sells electronic valve simulators so u get no fault codes.
    Oct 28 2012
    near chicago
    If awe sells this, and assuming there might ba feedback signal, funny a reputable company like magnAflow does not address it. All just guessing at this point but I'm going to assume (and hope ) there isn't a signal to the ecu.
    Edit: ok, so you were correct; http://www.uspmotorsports.com/Exhaus...imulators.html
    No cel in cluster, but a code stored nonetheless
    Established Member Two Rings bthomas22's Avatar
    Aug 26 2015
    Cumming, GA
    I wouldn't go with a magnaflow setup. I had the full cat-back system installed on my A7 and it had horrible drone on the highway and constantly rattled due to a poor design. I have since removed it and put my stock exhaust back on.
    2012 A7 Premium Plus Sport- APR Stage 2+ - Dual Pulley - AWE Quad Exhaust - AWE Resonated Downpipes - Roc Euro Intake - HRE FF01 Liquid Silver Wheels, 20x10.5 square setup - H&R Lowering Springs - RS7 Grill - S7 Rear Valance - 034Motorsport Drivetrain Mount Package - 034Motorsport Control Arm Kit - 034 Rear Adjustable Swaybar
    May 17 2016
    Seal Beach, CA
    My S6 was used by Magnaflow to build this exhaust. Its the silver car in the videos they posted. I like it. Sounds much deeper than stock at start up, idle and on acceleration. might drone a little, but not enough that it has ever bothered me on longer drives. Have a few launch videos on my IG, hortikris. Well worth the price vs other systems IMO.
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    Front dual res delete and mid suitcase delete.
    Still needs more of a growl when wot or even just reving it seems too quiet.
    Going to replace oem mufflers with a pair of magnaflow race mufflers.
    Hopefully this set up doesn't create too much drone.
    Anyone have any experience with their race series mufflers?
    2007 RS4
    2000 B5 S4 stage 3
    Jan 10 2016
    Ohio
    Quote Originally Posted by 1975audi View Post
    I don't know whichMagnaflows mine were - didn't realize it had them until i had my AWE put on. Anyway, mine had the suitcase removed and had no drone. Plus, the guy that had this done had the OEM valves welded in right behind the magnaflows. It was a decent setup, but still had a "pft, pft, pft" sound to it. Wife said it sounded a bit like a paddle boat, so I sprung for the AWE Touring. It's actually quieter than the suitcase delete/magnaflow setup by a touch - but the quality of the sound is much better IMO. No drone with either setup - and the old one had straight pipes welded in place of suitcase - i.e. no X or H pipe.
