Results 1 to 8 of 8
    Established Member Two Rings Bumpo411's Avatar
    Jun 09 2015
    Portland, Maine
    Broke down on the side of the highway
    Driving I93 to a concert going around 80 (speed limit is 70) and noticed my coolant light come on and my temp gauge spike at the same time so I pull over. Noticed coolant leaking so I let it cool off and I top it off with more coolant and turn around to head back home. Barely make it a mile and my light comes back on and coolant is now completely gone out of it. So I get the car towed and a friend picked me up and head back to the concert. I also noticed the power steering got stiffer.
    So my question is that, should I look at something specifically or do a general look around when I get back home? The reason why I ask is because the power steering stiffening up is throwing me a curve ball.
    Aug 19 2013
    minnesota
    Check the coolant flange on the back of the head and the top heater core hose coupler which connect to it. One or both of those things could be bad in this case. Those aren't things that are easy to keep an eye on so they typically fail catastrophic Lee at the worst times. At least unexpectedly. You can check your radiator as well. Or maybe your head is cracked or head gasket is bad.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Aug 19 2013
    minnesota
    The thermostat is supposed to fail in the open position but it is possible that it will fail shut.
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by Bumpo411 View Post
    Could be something simple as a cracked or torn hose, plastic coolant adapter or coolant flange / sensor retaining clip, etc. Or something more major like a water pump bearing or the radiator. Best way is the pressure the system and look for obvious leaks. Good luck.
    B6 USP Avant
    USP CLUB MEMBER #242
    AMB + GSX28RS
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    Perhaps coolant on the ACC belt causing slippage ?
    Junior Member One Ring nateehl's Avatar
    May 08 2016
    '10 A6
    Mesa, AZ
    Quote Originally Posted by jacobsen View Post
    Not saying this is what happened, but I have had my thermostat fail in the closed position, just 2 weeks ago actually.
    Dec 05 2007
    Check your PS reservoir and serpentine belt, too. Locate source of leak...replace compromised part.
    Jun 09 2015
    Portland, Maine
    Scanned my car when I got home and these codes came up, as well as misfire codes. Could these be related to having all of my coolant leaking out of my car?
    16399 - Bank 1: Camshaft B (Exhaust)
    P0015 - 002 - Advance Setpoint not Reached (Over-Retarded) - MIL ON
    18405 - Friction too High; Exhaust Cam Adjustment Bank 1
    P1997 - 002 -
    19537 - Engine Temperature too Low
    P3081 - 008 - - MIL ON
