Results 1 to 12 of 12
    Apr 15 2014
    Ottawa/Gatineau Canada
    Can I remove the 3 nuts on DS and PS that hold bumper on, and leave it like that?
    The front bumper is held on my the 3 nuts on each side in question, 2 bolts that go into the front crash bar and 2 or 4 more bolts up above the headlight.
    I am wondering if I can remove the 3 bolts on each side and just leave the remainder of the bolts to hold the bumper on? This would allow for front bumper removal without the need to remove the headlights to get at these 3 nuts.
    Anyone ever do this ?
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Mar 27 2014
    06 Grand cherokee, b6 a4
    Philadelphia
    Mine is only held on buy the 6 bolts in the fender wells. When I bought the car the bumper was off wasnt aware there were bolts on top also holds just fine for me
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    Im sure you can but the bumper may sag a little bit in the center.
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Apr 15 2014
    To clarify, thanks to Bmase fir the correct terminology...
    I am speaking of removing the 6 bolts in the fender wells, and leaving the remainder of the bolts in place.
    Mar 27 2014
    Philadelphia
    The bumper wont hold on to well Its not to hard to peel the fender cover back to remove bolts or maybe even drill 3 holes for 10mm socket to fit in the hole for easy access but other then that i dont see it holding with out the fender bolted to the bumper
    Mar 21 2016
    69 Nova
    California
    The bumper isn't held on by anything by the headlights. It's just the two bumper shock bolts and the three nuts on each side.
    I think you're thinking of the bolts you need to remove to put the front end into the service position.
    12 S4 Quattro 6 Speed
    04 A4 3.0 Quattro 6 Speed
    69 Nova with a bunch of stuffs
    19 Sportster 883
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    Quote Originally Posted by DarkoNova View Post
    hes talking about those 3 nuts on each side I believe, And I would not recommend it as a good gust of wind on the highway can pull the bumper from the lower clips if those are not in. Not likely but it could happen. Its not like removing the headlights is hard, its a 2 minute job.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by blitz2190 View Post
    Agreed. I have the Evolution Racewerks comp FMIC and the bumper is now only held on by those 6 fender to bumper bolts. I can't see anything good coming out of not using those to hold the bumper on. They keep the gap tight and if not used, the bumper will pop out of the side retainer that holds the lower spoiler on.
    B6 USP Avant
    USP CLUB MEMBER #242
    AMB + GSX28RS
    Apr 15 2014
    Correct, thank you for the clarification...I had the 2 procedures melded into one in my mind.
    Quote Originally Posted by Bmase View Post
    Now there is a smart idea, especially with all the other concerns regarding not using these fender well bolts.
    It is not the removal, it is the re-aiming I like to avoid if possible.
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by Luxus Panzer View Post
    Shouldn't have to re-aim. They never go back in the same spot but close enough that re-aiming shouldn't be needed.
    B6 USP Avant
    AMB + GSX28RS
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Just mark any bolts that may affect the alignment. I remove my headlights in about 5 minutes. They go back in and the alignment rarely needs tweaking.
    Apr 15 2014
    Smart.
