Results 1 to 3 of 3
    Feb 21 2017
    Eindhoven, Netherlands
    Angry MMI Basic Plus 2G is driving me crazy
    Hello guys.
    A6 C6 2.4 Avant 2006 with MMI Basic Plus 2G (small red monochromatic screen) with a 6-CD player.
    I'm looking for a way to listen to music from my smartphone and after doing some research, I found out that there is no way I can do that unless I change my MMI to the High version.
    This is what I found as common tricks to listen to music:
    1 - Upgrade to MMI High (expensive).
    2 - Install AMI (but it doesn't work for MMI with small monochromatic screen and it's a bit expensive).
    3 - Using a FM Transmitter (but most of the reviews are bad, either bad quality sound or FM interference.
    I found that Tune2Air, and it looks perfect, but I would need to connect into the AMI, that requires a MMI High.
    I just want to hear some music from my phone!!!
    A simple aux port or basic Bluetooth would be more than enough for me... isn't a simple solution for this ? I'm willing to remove de CD player if necessary.
    So, my fellow MMI Basic Plus 2G owners, what did you do ?
    Cheers!
    Stage 2 Banner Advertiser Four Rings Christian@enfig's Avatar
    Jul 12 2004
    2013 CC Executive Edition VR6 3.6, 2003 GLI VR6, 2005 A4 cab 3.0 V6, 01 GTI VR6. Past 89 & 78 Golf
    Carlstadt, NJ (outside of NYC)
    Here are all your options.
    THIS IS JUST FOR THE MMI2 LOW WITH THE RED SCREEN!!!
    I have only seen this screen in the US in two 2007 Q7's.
    The phone options usually does not work.
    http://enfigcarstereo.com/ENFIG_AUDI..._A6_A8_Q7.html
    iPod/iPhone AUX USB (old 30 pin with low charging for old ipods)
    http://enfigcarstereo.com/DENSION_GW51MO2.html
    iPod/iPhone AUX USB
    http://enfigcarstereo.com/DENSION_GW53MO2.html
    iPod/iPhone AUX USB + Bluetooth
    http://enfigcarstereo.com/DENSION_GW52MO2.html
    EnfigCarStereo.com - Audi Car Audio Integration Specialists
    ☎201-490-5015 - Instagram - Facebook - [email protected]
    Want to make some money while posting? Join our affiliate program.
    Apr 13 2016
    Warsaw
    Hi
    If you have DSP in trunk, you should have then you can add AUX IN, please read this topic:
    http://www.audizine.com/forum/showth...9#post11552149
