Results 1 to 9 of 9
    Established Member Two Rings saw76's Avatar
    Nov 30 2012
    2010 Audi S4 3.0T-2011 A3Quattro,2005Passat
    Marlborough, MA
    P3 gauge methanol flow meter ???
    Has anybody tried to hook up a methanol flow meter and tie it into a p3 gauges additional input so that it reads and displays flow rate on the gauge ?
    I did a quick search and didn't come up with any posts . I guess blue and brown wire on p3 gauges are the extra 0-5v inputs ??? Id like to do this . From what I have read the aquamist sensor is the best one that doesn't fail as often . Not sure how it ties in tho or what to do ?
    2010 ibis white s4 6mt 3.0T APR STAGE 2 with Snow Performance stage 3 Methanol Injection* 2011 A3 Quattro 2.0t s-line deep sea pearl blue metalic,APR full load tune.
    Apr 05 2016
    Portland, OR
    I looked into it with my AEM kit but it wasn't worth the extra cost to me.
    I do have the status LED for the AEM kit right above the P3 gauge so I can monitor flow that way.
    Geoff
    Nov 30 2012
    Marlborough, MA
    Yes but that just shows on and off power to the pump ? I have the stage 3 kit by snowperformance and it shows the same.
    But I had a nozzle clog up and it still showed pump on and pump off, I had no idea for a few days and realized I still had a full tank of methanol when I went to fill it up.
    This is why Im looking into a flow meter.
    The P3 has inputs and I would love to just tie into it. The aquamist kit is about 130 for the sensor and wire harness
    Apr 05 2016
    Portland, OR
    Took a bunch of digging but I was able to find a water flow meter for a coffee machine that can hold up to the pressure of the pump and might have a 0-5v Analog output.
    It might be a PWM but I am not sure as the description was vague.
    It was $10 and should wire up pretty easily. I'll let you know if I make any progress with it when it comes next week.
    Geoff
    Nov 30 2012
    Marlborough, MA
    ohh nice !!!! Thanks so much !!!
    This is the meter I found http://www.aquamist-direct.com/806-5...nsor-assembly/
    This is the harness for it http://www.aquamist-direct.com/806-5...-sensor-cable/
    wasnt sure of voltage signal and how that worked tho. Thats why I was on here checking.
    Apr 05 2016
    Portland, OR
    This came in today:
    I'll test the output tonight to see if it is PWM or 0-5v.
    Geoff
    Nov 30 2012
    Marlborough, MA
    Oh cool ! How did it come out ?
    Sent from my iPhone using Tapatalk Pro
    Apr 05 2016
    Portland, OR
    Working on a project for school currently.
    Going to work on getting it installed tonight or tomorrow.
    I'll keep you posted.
    Geoff
    Veteran Member Four Rings Rodizzle's Avatar
    Jun 17 2015
    Bayarea
    Geoff , did you get the sensor to work ?
