Front and rear Seats (Black Leather / White Alcantara) with some wear on the front Alcantara bottom sections (mainly driver seat). Leather in good shape with no rips, tears or scrapes. - $
Black Headliner - $80
Black Rear deck cover - $25 (some color fade from sun)
Black leather arm rest console - $80
Black Interior Parts - Misc parts still available, message me or just come see what I have.
Damaged dash - $50
Drivers lower dash section (around steering wheel - light scratches - $50
Instrument cluster - typical dead pixels - $100
Pedal assembly (manual) with AWE tuning metal pedals - $150
Bare shell - Completely bare, no sub-frames or anything. You haul. Most of the interior harness still installed with misc small items like gas door lock - Hit in front, firewall forward gone. All doors opened, closed and sealed perfectly, no roof damage. Could be used for race car shell or (more likely) cut sections for another car - $200 price goes up significantly if you want help moving it (I can deliver locally, but my time is limited right now due to work).
Complete Door Assemblies, with glass (18% tint), clean door cards (black leather, white alcantara) All clean paint with the exception of a small nick on the drivers front door from the road - $650 takes all 4
Sunroof assembly - 18% tint - fully functional - $200
Rear trunk assembly with hinges - $175
Rear Bumper - scrape on lower drivers side, otherwise clean - $225
OEM S4 side skirts - some scratches - $150
Gas Tank Lid - $30
Front strut assemblies with hubs, brakes, control arms etc and rear strut assemblies - $275
Rear sub-frame assembly complete caliper to caliper - one bent drivers control arm where stupid tow truck driver strapped car down - Differential in good shape, royal purple full synthetic gear oil changed every 25k - $400
AWE Tuning Cat back 2.5" dual exhaust with JHM 3" catless down pipes with o2 spacers - down pipes need flex pipe welds redone (they leak slightly). Early JHM down pipes had weld corrosion issues due to filler metal and type of stainless used - $475 as is or for $650 I will clean and tig weld the joints.
Aftermarket HID Ballast (ECS Tuning) - less than 2 years of use - $125. I'll throw in the second one that may not work anymore to whoever buys (worked when removed but got wet due to roof leak, board has corrosion)
OEM fuel tank assembly with filler & charcoal canister attached - $100
Forge Diverter valves - with attachment lines and up pipes as shown - $150
wiper motor and arm assembly - $40
ABS pump module - $75
Steering Column - $75
AWE tuned ECU (Stage 2) - $300
Side Curtain Airbags - $75
Steering Rack - $ 100
Rear tail lights - not oem - clean - $75
S4 steering wheel (no airbag)- $75
hvac air blower unit (under dash) - $80
Brake master and booster - $80
I will update pictures and add more parts later this weekend.
