Yesterday I had all my Eurocode parts installed on my MY16 S6 and the car feels much more planted on the road now. At the same time my shop tried to lower my car using VCDS. Three of the corners had no problem going 17mm lower but one would not do 17mm, 15mm, or 12mm. So they put all four corners back to the original ride height. The corner that did not work already had 401.90mm while the other three were between 385.70mm and 394.50mm. Perhaps I try again myself with some smaller numbers (e.g. 4-10mm) if I can find a perfectly level area. The guy at my shop suggested lowering links and discouraged lowering modules. He told me a buddy of his installed a lowering module and doing so fried the ECU. Also, lowering links are much cheaper than a lowering module. Any advice from folks out there who have lowering links? Which brand should I get and do they require re-calibration of the driver assistance sensors and/or cameras? Also, any advise how I could still get the VCDS to work (perhaps lower incrementally rather that trying to do it in one step?) or lowering links vs. lowering module?
