Results 1 to 3 of 3
    Established Member Two Rings DAYTA's Avatar
    Dec 30 2014
    When do you replace your fuel pumps?
    Since my RS4 now has 124k miles on it, I'm looking to do some preventative maintenance in the very near future. I plan to replace all 8 injectors and do a carbon clean since I don't have records of when (or if) they were last done.
    However, I haven't read much about guys replacing their fuel pumps (HPFPs especially) as a preventative measure. Are these components that the RS4 needs to have monitored, and if so when do people typically replace them?
    Daily Driver: 2016 VW Golf R
    Family Hauler: 2018 BMW X5 xDrive35i
    Weekend Toy: 1997 NSX
    Veteran Member Four Rings MugelloB7RS4's Avatar
    Feb 06 2015
    I've replaced mine a couple times but only because the solenoid valve on the unit started throwing codes. I don't think there's any reason to do them early if they're working properly. Maybe piece of mind, but they're a quick and easy replacement once codes start popping up or you start to notice issued.
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    If you have access to a vag-com cable (if not I would recommend you get) you can monitor the pump duty cycle and rail pressure under Engine[01] - group 140
    There you can see the duty cycle of the LPFP and the requested/actual rail pressure. If these numbers deviate then you know that something is up with one of the 3 pumps. If they are all working fine, I would leave them in your place and only change the fuel filter.
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
