Ok I have searched threads on here for a while since getting my B8 S4. Enough different opinions on here to make my head spin.
Trying to decide what to do with suspension on this car. Want to get it handling better but also looking for less fender gap when I fit by 19x9.5" Braelin BR-07 wheels (+35 offset) in the spring.
This is basically the look I am looking to get (except my car is red), but it doesn't have to be quite that low:
http://www.pictaram.com/media/128355...703_1560550429
I had FK coilovers with RS4 sways on my B6 S4 and didn't mind them too much, but felt they were a bit bouncy and under-damped at times. I had them raised up a bit for a BIT of fender gap as my wheels were completely flush fitment and I wanted to keep from rubbing
I found a cheap set of ST Suspension coilovers for sale locally for a few hundred bucks, and read a bit about them. Made in association with KW, so I am guessing decent ride quality, looks like they have at least SOME corrosion resistance. I am wondering if they are a good choice for the money. I am trying to watch the budget a bit. Alberta winters around Edmonton are relatively dry and I don't do lots of winter driving with the car. I also don't need to have the car slammed. I prefer to keep it where I know I have a BIT of forgiveness for rough roads and avoid rubbing. That might be where appropriate tire choice comes into play so I appreciate any advice on sizing those too. I am a bit concerned as I had read somewhere that the rear of the ST suspension sat pretty low even when cranked up as high as it allows.
Not 100% sold on coilovers if there's other good options, but I want to make sure I can have the car sitting the way I need it to. I don't mind firm ride (I had FK coilovers before) as long as it isn't bone jarring, but I am mostly concerned with ride height and trying to avoid bouncy this time around.
Thoughts and suggestions? Would love to keep it $1500 Cdn or less so I am looking at budget and lightly used higher end suspension options. $500CDN is pretty tempting to try the ST suspension which are lightly used with not many miles (owner went air ride)
Eventually my other suspension plans include end links and upgraded sway bars, maybe the subframe brace upgrade too.
