Results 1 to 30 of 30
    Deactivated Two Rings
    Dec 27 2016
    Mass
    Help! WTF is this LOUD sound?
    Car is a 2013 Audi S6
    Video: https://youtu.be/FrioihNMfqs
    Just started happening. There are some similar videos online, but I am not able to determine what it is similar to. I figure somebody on here with a better ear than I will be able to tell me.
    Car is covered under warranty, so my main concern is drivability until I get it to the dealer.
    The sound can be heard outside the car from 100 feet away, it's that loud. Definitely coming from the engine compartment.
    • The sound can be heard outside the car from 100 feet away, it's that loud.
    • Definitely coming from the engine compartment.
    • Does not seem to change with engine RPM.
    • AC/Heat does not matter
    Oct 22 2013
    Bicycles
    United States
    Haha, my 2013 S6 started doing that about 3 weeks ago. It's a leaking oil separator. You can drive it. It only makes a noise at light loads.
    I replaced mine myself in my garage for about $220.
    Sent from my ONE A2005 using Tapatalk
    May 24 2015
    NW
    Other threads with a similar sound think it is the PCV valve.
    http://www.audizine.com/forum/showth...rom-engine-bay
    Jan 24 2008
    Pennsylvania
    So based on those vids, with the car running, remove your oil cap, see if the noise goes away. If it does, PCV
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Dec 27 2016
    Mass
    I'll try that next.
    Junior Member Two Rings bander2586's Avatar
    Oct 27 2014
    Los Angeles, CA
    Same exact noise on my 13 S6. Had fixed last month under warranty..... faulty Crankcase Pressure Regulating Value.
    Active Member One Ring Mike2489's Avatar
    Jan 15 2014
    California
    Mine just did it tonight. So glad I'm not the only one. Have 78k miles on it. I was hoping it wasn't the turbo. Thank you.
    Feb 11 2016
    earth
    Quote Originally Posted by bander2586 View Post
    It is this. Just had this repaired last week under warranty
    Established Member Two Rings AntonioS6's Avatar
    Jun 14 2016
    Connecticut
    sounds like a Bill Murray issue
    2018 BMW M5 Black Sapphire Metallic
    GONE - 2013 Audi S6 Phantom Black Pearl
    Dec 27 2016
    Mass
    Turned out to be a breather problem fixed under a TSB (warranty). Thanks for the help!
    Sep 28 2009
    suburb
    My car just started making this noise. Hopefully I can get into the dealer soon. Sounds terrible! My boost is also cut too!
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Sep 28 2009
    suburb
    Can you drive around with this issue while you wait for dealer appointment?
    Audi SQ7
    Audi B8 S5 (gone)
    Established Member Two Rings ehofmann's Avatar
    Dec 22 2014
    Colorado
    You can but it was waaaay too annoying/embarrassing for me to drive daily. I just shared my wife's car for a few day until I could get it in.
    Sep 28 2009
    suburb
    Quote Originally Posted by ehofmann View Post
    I know everyone stares at me !
    Audi SQ7
    Audi B8 S5 (gone)
    Dec 05 2016
    Westminster, CO
    Yep, same thing with mine too. It won't start making the screech until the car is warmed up. Parts are coming this week.
    Sep 28 2009
    suburb
    i feel like my car smells smokey. I believe it is related to the failing breather valve? Besides the noise, is it OK to drive around for a couple of days?
    Audi SQ7
    Audi B8 S5 (gone)
    Dec 05 2016
    Westminster, CO
    Yep, sitting at a light I will get a whiff of breather oil vapors. I have noted a minuscule but nevertheless increased oil consumption too, which makes sense. When I get the oil separator out, I will try and figure out exactly what failed. The huge vacuum in the crankcase makes me believe that there is a valve or seal in the separator that is letting all of the crankcase air to be ingested in the engine, hence the increased oil consumption. While its not ideal, I feel it's safe to drive if you don't put too much mileage on it.
    On a fairly related note, I am planning on installing RS7 turbo inlets, baffled tubes, and RS7 airbox "while I'm in there". The problem? There is a nationwide shortage of left side RS7 turbo inlet pipes. Odd.........
    Sep 28 2009
    suburb
    Is your boost low? I get like 2 lbs of boost only...which makes sense bc if air leak. They don’t have opening for over a week at the dealer. Car is so embarrassing!
    Audi SQ7
    Audi B8 S5 (gone)
    Dec 05 2016
    Westminster, CO
    It builds boost much more slowly, but it will boost. I don't let any dealerships touch my car, I do all maintenance/repairs myself. I will try and document the process for others out there that want to tackle it themselves. Looking at the factory service manual, it doesn't appear to be that hard to replace, just requires draining the coolant because you are removing the intercooler. While being nestled in the V of the engine, access to the part doesn't seem that bad. This is coming from a guy who has seen the dread of others replacing an EGR cooler on a 6.0L Powerstroke...... :lol:
    Dec 26 2013
    Newcastle, WA
    please take pics as I think I'm going to need to do the PCV on my S6 sooner rather than later!
    Dec 05 2016
    Westminster, CO
    Yep, I am very meticulous about documenting things like this. Parts should arrive Thursday, but I am going hunting on Friday-Wednesday, so it will likely be next weekend before I can tackle the job.
    Dec 05 2016
    Westminster, CO
    All parts are at the house, minus the left RS7 turbo inlet pipe (still on national backorder). If anybody has a new or used one laying around, I'd gladly take it off your hands. I plan on starting this on Friday, maybe taking part of Saturday too.
    Nov 08 2017
    PA - USA
    I'm in the same boat for my 2013 S6. I guess SkyDude has a better source for parts than the dealer? I got quoted $658 just for parts.
    Found these other related threads:
    https://www.audiworld.com/forums/a8-...e-bay-2920973/
    https://www.audiworld.com/forums/s6-...t-diy-2921782/
    And a few links for diagrams & p/n:
    https://audi.7zap.com/en/rdw/audi+a6...145-145098/#1A
    https://parts.audiusa.com/p/Audi__/O...79103542E.html
    Found a kit:
    https://www.hstuning.com/product_inf...oducts_id=5579
    Looking forward to your results WhiteWhiteS7 !
    Dec 05 2016
    Westminster, CO
    Got it all done. Uploading pics and will have a separate How To thread for those that want to tackle this themselves. Overall, not horrific, but the lock carrier needs to be removed, something that didn't occur to me when looking through the procedure the first time.....
    Sep 28 2009
    suburb
    I had mine replaced by dealer. They said it would have been a 2k cost w/o warranty. I'm at 65k miles. I also had motor mounts replaced also and some bushings b/c of other noises.
    Audi SQ7
    Audi B8 S5 (gone)
    Feb 21 2018
    Westminster California
    Quote Originally Posted by WhiteWhiteS7 View Post
    Do you have the how to thread posted yet?
    Dec 05 2016
    Westminster, CO
    Yes, do a search.
    Mar 26 2010
    US
    BMW M3 Competition X-drive
    Jan 02 2018
    Deleted
    Does my 2018 have those same crappy parts? Just curious. Good luck with the fixes folks.
    Mar 26 2010
    US
    Quote Originally Posted by elptxjc View Post
    Most likely, since the same Separator Part Number: 079103542E is listed for 2013-2017 S6 & 2014-2017 RS7.
    Previous Revisions
    079103542B
    079103542D
