Results 1 to 3 of 3
    Veteran Member Three Rings ParadigmTony's Avatar
    Apr 02 2015
    Rochester NY
    2010 Audi A5 6MT K04+ - No Longer Available
    Final product. This 2010 A5 started life as 2.0l 4cyl with 211hp, great looks and average performance. Since taking ownership, every nut and bolt has been turned. Despite having 80k on the actual odometer the car actually only has approx 3500 total miles of ownership, and wear and tear on it. Every aspect of performance has been addressed methodically, resulting in a well balanced, and even better looking performance vehicle. Every wear item replaced. This body style will be iconic for years.
    Upgrades include:
    Stage 2+ CTS Turbo Upgrade (3500)
    CTS Front Mount Intercooler w/tubing (1000)
    Roc-Euro Cold Air Intake (450)
    GFB Diverter Valve+ (300)
    CTS Test Pipe (300)
    Milltek Exhaust (500)
    AWE Touring Muffler (1500)
    R8 OEM Coil packs (300)
    NGK Iridium spark plugs (75)
    Brand New Long Block from Audi (replaced under service bulletin)
    New Timing Chain, Tensioners and water pump (1600)
    KW ST Coilovers (1200)
    Eurocode Sway bars (500)
    Eurocode Endlinks (200)
    StopTech St60 380mm Big Brake Kit (4000)
    BBS Ci-R 19x10 (3000)
    Bridgestone Potenza RE71R 285/35/19 (1600)
    OEM S5 Front Bumper (800 +paint 300)
    OEM RS5 Front Grille (400)
    Honeycomb Lower Bumper inserts (300)
    OEM S5 Side Blades (300)
    OEM Euro-Spec Rear Diffuser (350)
    OEM Euro-Spec Headlights (1100)
    The modifications alone total 23,000+ and are worth the cost of the car. At 23k you're either getting a lot of parts free, or a free car with all your parts. All Original equipment included if interested. Im only selling because its time. I built it, now someone else should enjoy it, and thats what I really hope for this car. Its so much fun to drive, with 350 whp, all wheel drive, upgraded suspension and braking, and manual this car is a blast. Its never been tracked, but was built with recreational track use intended. Heres your chance to by an A5 faster than an S5 and RS and lighter. *more pics available upon request.
    List Date: 3/2/2017
    For more info, click here to view the original listing: 2010 Audi A5 6MT K04+
    This item is no longer available.
    Veteran Member Three Rings dennej1985's Avatar
    Jul 23 2012
    Wyoming
    Bump for a freaking beautiful car, just a bit more modified than what I am looking for....GLWS!!!!
    Now: 2014 S4 |6MT|Estoril|Lunar/Black|AFE|
    Then: 2012 A4 Quattro 2.0T 6MT
    2003 A4 Quattro Avant 5MT
    Apr 02 2015
    Rochester NY
    Quote Originally Posted by dennej1985 View Post
    Thank you
    //B8 A5 // 6MT DSB Pearl // Roc-Euro // APR // AWE // BBS // Bridgestone // StopTech // // K04/Stage 3v3/FMIC/Roc-Euro Intake/Test pipe-AWE touring/100oct life/19x10 CI-R/RE71R/ST60 BBK //
