Results 1 to 10 of 10
    Senior Member Two Rings 616_S4's Avatar
    Mar 07 2016
    2001 S4
    Grand Rapids Michigan
    Anyone converted their twin 2 exhaust to a twin 1?
    Reason I ask is because I have an XS power twin 2 but would like a little more noise.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Take it to a local Meineke or muffler shop and have them cut out the rear muffler. Should cost like $50-75
    Apr 07 2011
    Home of the mighty beaver
    personally id like less noise.
    Sep 07 2012
    Tucson, AZ
    I think the twin 2 is perfect and you may regret taking off that second muffler man. It has a nice mellow tone when cruising and roars when you open it up. Isn't obnoxious when cruising on the highway with any drone either with catless DP's which is great. But, if you like drone and 24/7 noisy exhaust then go for it! I must be getting old lol
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Quote Originally Posted by LightningLou View Post
    nah I feel you man. I had an ASP TruDual with open 3" DPs and it was hearing-damage-worthy (because I have it) at highway speed. Went to the Twin2 to get the best of both worlds. Tunnel blasting, and saving my ears from 103dB in-cabin (with ASP on my setup).
    Remember, you might not be able to hear it, but I assure you that everyone else can with a Twin2.
    Apr 07 2011
    Quote Originally Posted by MikeyB3 View Post
    I have the asp true dual as well, and i concur, drone city, way too loud
    May 08 2016
    Manhattan
    I turned my awe twin 2 to a twin 1 I cut the muffler out and welded in new piping. Worked well sounds the same as my friends legitamite twin 1 haha
    Veteran Member Three Rings B501S4's Avatar
    Sep 09 2007
    01.5 B5S4 Stg III RS6's Built Longblock, Cherokee Classic 4x4
    Raleigh, NC
    OP, If you decide to do it, delete the rear muffler/resonator, will keep cabin drone down (more so than if you were to delete the mid).
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    i think it really depends on the turbos you have.
    from what i've seen k03 cars seem to be much louder than their k04 / larger turbo counterparts.
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    Quote Originally Posted by erykv1 View Post
    ^this. I've noticed my new setup with K24s is a bit more muffled than my K04s. Exhaust is the exact same setup in both scenarios.
    I run a Twin1 with Catless AWEs. I like it nice and loud. Minimal drone surprisingly. I enjoy setting car alarms off with it too. But I'm also very young and immature lol.
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
