OK so I've been fighting limp mode for months now. When it first started I thought it was my n75 valve. Replaced it with a grimspeed MBC. Which now allowed me to make over 5psi again but occasionally the car would try to go into limp mode causing the dash to light up (traction control, suspension, and abs). I also would get a code for maf circuit to high (p0103) only thing I could come up with was boost leak, car still ran good with the MBC and boosted just as it should 18psi stage 2. I had done a boost leak test when this first started and found a torn tbb, so I replaced that. Couldnt find any other leaks so assumed I was good. Didn't fix my issues, I just installed a fmic so figured I'd do another boost leak test, found some small leaks but nothing major. I also checked the vacum lines to the wastegate and they hold vaccum like they should. I then went for a test drive and now I can't build boost. It will maybe get to 5psi but it struggles to hold 1-3psi. I have tried hooking the n75 back up same results, I've tried driving without the wastegate vac line hooked up, same results. I've even tried driving with the vac lines to the diverters unhooked thinking they were being help open getting vac when they shouldn't. No change. I'm so confused as to what is causing this and if my two issues are even related. Turbos make 0 noise, no smoke, and were tight as of 1000 miles ago when I gutted my downpipes . Please help!
