Results 1 to 20 of 20
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Changed PCV & N80 valve
    Hey guys, to follow up on this thread http://www.audizine.com/forum/showthread.php/691104-PCV-install-with-intake-manifold-in-place/page1
    Symptoms:
    - car was leaving a cloud of smoke when accelerating
    - using up more oil than usual (within normal RS4 spec)
    - when removed the oil filler cap, there is a strong vacuum and the engine started sputtering badly
    My conclusion was that the PCV is on its way out:
    - changed the PCV (got it for 140€ from the dealer)
    - no more smoke and oil levels normal (better than normal RS4 spec)
    - vacuum at oil filler cap persists (not as strong), engine still sputters (not as strong)
    After this I read that the suction may be due to a bad N80 valve. So I got an N80 valve (20€ at the dealer) and changed it. Vacuum and light sputter still persist when oil filler cap is removed.
    Is the slight vacuum and sputter still normal after changing both PCV and N80 valve? Car runs normal and strong, cylinder compression ok, etc. I also did a borescope and compression test, all cylinders are 11-12bar (160-175psi) and walls are like a mirror thankfully. Small noticeable carbon deposits on valves and pistons. Last carbon clean is 15k km (10k miles) ago.
    New PCV:
    Old N80 still installed during the PCV exchange:
    New N80:
    Compression examples:
    Borsecope Bank2 Cyl5 examples:
    Top piston & cylinder wall:
    90° mirror borescope for cylinder wall and valves:
    Borsecope Bank1 Cyl2 examples:
    Cylinder wall reflection:
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Account Terminated Four Rings Quattrors4's Avatar
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    some vaccum is normal in the crankcase it should be -2hg to -3hg,when you open your oil filler cap you introduce a vaccum leak in the system and your short term ft will compensate,yes its normal if the engine feels rought
    May 10 2015
    Slovenia
    Quote Originally Posted by Quattrors4 View Post
    Thank you for the quick and detailed explanation! I was thinking the same, reading the PCV threads in the A4 sub-forums.
    James May: "Yes."
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by ven0m View Post
    [IMG][/IMG]
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    As an aside, the PCV part for Q7s and Touaregs (with the lower revving 4.2FSI) is the exact same and costs fractions of the RS4 part cost.
    Part number is: 079103464D
    The only difference is that the oil drain tube at the bottom of the PCV points straight down instead of at a 90 degree angle, but it all still fits just fine.
    2005 Ferrari F430
    2007 RS4 Daytona Grey | 2008 RS4 Mugello w/Ti Package | 2007 RS4 Avus Silver (ex-Audi Corporate) | 2008 RS4 Avus Silver w/Exclusive Package
    B6 S4 Avant 6MT Dolphin Grey
    B5 S4 Avant 6MT Laser Red Stage 3+
    B5 S4 Sedan 6MT Silver Stage 1
    Feb 13 2004
    AW E30 M3 & PB B7 RS4 (DD)
    Quote Originally Posted by Fourplay View Post
    Great info. ECS has that part number for $260 but Amazon only $39. Why so much differences?
    May 01 2010
    Atlanta
    Quote Originally Posted by d2a4 View Post
    The ECS part is OEM, so it was made in China, shipped to Germany, then shipped to the states, then given the OEM VAG markup.
    The Amazon part skips all of the intermediate steps. You're buying direct from the manufacturer in China. It is the exact same part, down to the cyclonic oil separators and rubber diaphragm.
    2005 Ferrari F430
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    Can we get some links to parts here gentlemen?
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    has your coolant been dropping at all?
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Feb 13 2004
    Quote Originally Posted by Lugi20 View Post
    Just copy & paste the part number Fourplay provided in google search & everything come up nicely.
    May 10 2015
    Slovenia
    Quote Originally Posted by your daddy View Post
    Nope, coolant was always at the same level. Only fluids topped up were oil and a bit of the hydraulic fluid, because I washed out the power steering pump some time ago.
    James May: "Yes."
    Forum Moderator Four Rings docurley's Avatar
    UK London
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    May 01 2010
    Atlanta
    079103464D - oil separator for 4.2 and 5.2 FSI - $40
    Amazon Prime link: https://www.amazon.com/gp/aw/d/B01GC...rds=079103464D
    079103464F - RS4 specific part, identical to above part minus oil drain hose orientation (horizontal vs vertical) - $355
    https://www.ecstuning.com/b-genuine-...cv/079103464f/
    Established Member Two Rings 2QK4U's Avatar
    Aug 04 2012
    Nevada
    Question: Is there a timeframe/mileage when you should replace the N80?
    2007 Audi RS4 - Phantom Black. APR TVS1320 Supercharger. Milltek downpipes & exhaust (100 cell cats, non resonated, valved).
    JHM Stage 3R Series Flywheel, Clutch, Pressure Plate. JHM Short Throw Shifter & linkage. 034 Motor, Torque & Trans Mounts. Apikol Rear Diff Mount.
    Deflapped intake. K&N drop in filter. Decarbed.
    Senior Member Three Rings Dirtracer603's Avatar
    Aug 15 2012
    Custom stunt CRF250 supermoto, 06 CBR600rr
    Fredericksburg, Va
    I have recently been reading/considering going to atmosphere with my PCV gases with a drainable catch can and vacuum pump and also making necessary adjustments to the PCV port on the intake. Mainly to keep the intake clean from carbon deposits. Any insight from you guys on this?
    Sent from my SM-G900P using Audizine mobile app
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by Dirtracer603 View Post
    there is a good way to keep your intake manifold clean off oil I will post a picture of the set up a bit later ,the way people install there catch can is wrong on those motors that's why they don't work
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    [IMG][/IMG]
    whats happening with the stock system is that there is so much oil going thrue the breather that it can t cope with all the oil in the ventury system and it cant drain it fast enough and some oil find its way into the intake manifold,by doing the set up shown above the catch can picks up all that extra oil and the intake manifold stays oil free
    Jan 29 2017
    B7 RS4, B15 Sentra Spec V
    San Antonio, TX
    Yeah, you are aware that there is some what of a difference between how you set up a catch on a NA car versus an FI car right.....?
    I still need to dig around on this motor but if the system is like normal, then technically we would need two cans or a 2 in/1 out can for pcv and vc.
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by CrickiKaze View Post
    I had the same system when I was na and it was just perfect,no trace of oil in the manifold,for the fi I use one more catch can with a 1 inch check valve to realease pressure on boost
    for na you don't need 2 cans
