Results 1 to 23 of 23
    Dec 18 2008
    Virginia
    Grease coming out of rear cv boot. Can't see a tear
    Hi, had this issue for a while when I swap out my summer/winter wheels I notice from grease in my ear driver inside wheel. Because of this silly winter in nova, I put back on my summers today. Saw a lot of grease. I notice there is no clamp on the rear boots. I guess the grease is coming out because of that? Any one experience this? See pic
    Dec 18 2008
    Virginia
    Also, any diy for replacing rear cv boot? Found one but wasn't sure that was the best way to do it. Thanks
    Jun 17 2013
    jersey city nj
    ing at the picture from that angle it appears the boot at cracked at the rib
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    If this has been going on for a while, you're better off replacing the axle.
    Jan 15 2012
    k20 Integra
    LA,CA
    Looks broken at that first rib, and the fact that there's no clamp probably means it's coming out of the back as well as that spot. If the boot is okay, i'd replace the clamp with one of those screw in type's. If it's ripped I'd replace the axle.
    Dec 18 2008
    Virginia
    thanks, I took the pic today without really getting back there....was in a hurry to get somewhere and wanted to switch wheels....will take off wheel and do full inspection...If I do need a new boot, anyone know a good diy for removing it? ELSA only shows how to remove entire axle which they say to remove the rear spring. ugh.
    Thanks
    Jan 15 2012
    k20 Integra
    LA,CA
    Quote Originally Posted by mudd1011 View Post
    Thanks
    My opinion trying to swap the boot.
    If you have to, it's a lot easier to take the axle off and line up/knock in the cv joint with the axle off than with it on the car if you don't just replace it. Removing the axle shouldn't take more than 30 minutes. A spring compressor isn't difficult to use. It took me a couple of minutes if that, to remove the rear springs.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Quote Originally Posted by JayDog747 View Post
    Why not just replace the boots if the axles are not crackling while turning?
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Mar 24 2013
    Oakdale, CT
    Both my rear axles did that. There is no clamp on that part of the boot from the factory. Not sure what causes them to leak. I put zip ties on both of my boots to snug them up and they stopped throwing grease everywhere. Worked great for another 30k miles or so until the car was totaled. I still have those axles as a spare set and they look/feel fine.
    -Adam
    Dec 18 2008
    Virginia
    i thought about putting a hose clamp on it but not sure how much grease is still in there.... I guess there's no way to pump in some more grease with out taking off the boot? I'm not hearing any noise or anything
    Mar 24 2013
    Oakdale, CT
    If it just started, you should be ok.
    -Adam
    Aug 02 2016
    for the extra few dollars just get the axle . That is what I am doing this weekend.
    USP CLUB MEMBER #213
    |2005 A4 1.8T Quattro- Ultrasport S-Line Package | Brilliant Black | Stage 3|
    Mar 10 2010
    WI
    Quote Originally Posted by 80sGuy View Post
    I find my time more valuable than packing fudge in a hole! I'm sorry, I meant grease into a twelve year old part.
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Dude zip ties are life savers. I love those darn things. I have done a whole bunch of voodoo on my cars with zip ties haha
    Sent from my C5306 using Tapatalk
    Ivan
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    Woah, your time must be really valuable.
    An axle thats actually worth putting onto your car (aka raxle or OEM) is exponentially more expensive than a boot kit, if you want to talk about time and value. Id ask you to explain your logic, but since you already made an attempt at a fudge-related joke, I'm sure I won't like the answer
    Casey | @cshore | B7 A4 Avant 2.0T | B8 Q5 2.0T
    Jan 15 2012
    k20 Integra
    LA,CA
    You can put the grease into a syringe and stick it up underneath the booth and squeeze it in. I've done that before then seal the boot.
    Quote Originally Posted by Low and Behold View Post
    Aftermarket axles are are 1/7 of the price and carry a lifetime warranty. Why anyone would pay $700 for an OEM axle is something I'll never understand.
    Aug 19 2013
    Miami
    Quote Originally Posted by dwinters14 View Post
    I created a boot of tape on my front cv axle for like a month and put some grease on there until i had time do buy a new axle haha ghetto but it worked.
    Ivan
    Oct 09 2007
    Miele S7
    I agree with you on the grease, but not on the fudge.
    Feb 28 2017
    Eastern Europe
    I see no clip on the axle part of the boot. AFAIK there should be a small clip to keep the boot tight.
    Edit: Sorry. I've just read all the other answers now.
    Mar 24 2013
    Oakdale, CT
    New oem axles are a ripoff but raxles are worth the price. All other aftermarket axles are garbage and either never work or don't work for long.
    -Adam
    Jan 15 2012
    k20 Integra
    LA,CA
    I just replaced mine with a duralast lol I'll let you know when/if it gives. But so far so good! only 100 miles on it
    Aug 19 2013
    Miami
    Get back to us in 5k miles lol
    Ivan
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    If you want an OEM axle I have one sitting in the garage I'll sell for cheap. Gotta get rid of stuff.
