Results 1 to 39 of 39
    Registered User Four Rings EmmanueleDesign's Avatar
    Feb 11 2014
    2000 Audi S4, 1995 Audi S6
    Anaheim, CA
    Cool Now Available l eMMOTION Linear Lowering Spring Kit For Audi A4 Quattro (B9)!
    Established Member Two Rings Four rings fan's Avatar
    Sep 10 2016
    Florida
    Thanks for the detailed answer on your blog regarding trimming the bump stops.
    2018 S6 Mythos Black Prestige
    May 03 2016
    Can't recall if I asked this anywhere else but have you or do you plan to test these on an A4 Allroad?
    Feb 11 2014
    Anaheim, CA
    Quote Originally Posted by Fantasiamon View Post
    Most of the suspension part numbers are the same between the Allroad and Non-Sport A4, so the specs on the lowering springs will be the same. We do hope to have a local car stop by for photos and measurements though.
    Feb 11 2014
    Anaheim, CA
    Repost from Audi / Rings:
    Some feedback on the eMMOTION lowering springs installed yesterday.
    The drive back was about 25 miles, which consisted of light to light traffic, aggressive parkway entrance and exit, and going through a work zone (uneven, spotty roads with some pot holes), basically daily commuting condition in suburban New York.
    Ride height - much of the factory non-sport suspension gap is eliminated, probably an inch of gap left and would wait until it's settled to really give a verdict. The drop so far is ideal for my daily needs and I used to have a slammed sedan.
    Ride Quality - I think they nailed it when they said the ride quality isn't compromised and kept as close to stock. It felt close stock going over bumps, potholes and any other abnormalities the road had. A bit stiffer, but in a good way where you feel more planted at higher speeds and less body roll during aggressive driving.
    Product Quality - not much I can comment on this, I received the package and everything was packed nicely, 2 front springs with front bump stops and 2 rear springs. Even came with a bottle opener (kudos!) and lanyard!
    Customer Service - there was a little bit of a hiccup when receiving the package (thanks FedEx!) but I emailed Emmanuel Design to keep them in the loop and they were quick to respond. So far no issues, but I'm confident Thomas will do right with its customers.
    Overall, the springs definitely changed the vehicle dynamic in a positive way while retaining OEM feel. Basically an OEM+ upgrade and hopefully after a week or so, much of the positive will remain.
    Unfortunately with the winter storm, I won't be able to log any spirited/aggressive driving until the roads are clear.
    Feb 11 2014
    Anaheim, CA
    Repost from jorgecopa:
    "I finally had my EmmanueleDesign lowering springs installed. I'm amazingly happy with the ride quality and drop. The ride quality is very close to stock with very little change but the handling is much better. I'm not having any type of vibration or misalignment issues so far but probably get the alignment done anyways. EmmanueleDesign delivered on their promise to keep the ride quality intact and they succeeded.
    I had this negative thing that it was going to look slammed and that the ride quality was going to suffer but I was completely wrong. I will post pictures later on today."
    Thanks for the kind words!
    Mar 30 2017
    Brooklyn, NY
    This may seem like a silly question, however, I am a noob, so bare with me.
    The included bump stops in the kit replace the stock bump stops, so there should be no need to trim the bump stops?
    Looking into grabbing the stage 1 kit within the next few weeks. =D
    Feb 11 2014
    Anaheim, CA
    Quote Originally Posted by soysauceprince View Post
    The front bump stops will not require trimming, as they are replaced with the included units. We do recommend trimming the rear bump stops.
    Mar 30 2017
    Brooklyn, NY
    Quote Originally Posted by EmmanueleDesign View Post
    What would be the suggested amount to be trimmed for the rear?
    Feb 11 2014
    Anaheim, CA
    On the non-sport, we recommend trimming 1.0 - 1.2" off the rear with our lowering springs.
    Feb 11 2014
    Anaheim, CA
    Repost from BiscuitEmbryo:
    "I got the Emmanuelle springs and sway bar installed yesterday and I love it. The ride is maybe very slightly firmer, but not so much that it bothers me. It really is very close to stock.
    The sway bar, however, has made a huge difference. Body roll is dramatically reduced, especially in long, sweeping turns (like on an exit ramp). Overall the suspension feels much tighter."
    Feb 11 2014
    Anaheim, CA
    Veteran Member Four Rings STICKY RICE's Avatar
    Mar 29 2012
    B9 S4
    California
    Set aside a set of springs and sway for me, Thomas. Just finished talking with the dealership. Goodbye S3 and hello S4.
    Feb 11 2014
    Anaheim, CA
    Quote Originally Posted by STICKY RICE View Post
    Feb 11 2014
    Anaheim, CA
    Established Member Two Rings Da_Big_Sweed's Avatar
    Apr 14 2017
    Socal
    Loving my emmanuele design springs and say bar on s4 b9..rides like a dream and handles amazing
    Sent from my SM-G920V using Audizine mobile app
    Feb 11 2014
    Anaheim, CA
    Quote Originally Posted by Da_Big_Sweed View Post
    Thanks for the kind words, glad that you are enjoying them!
    Feb 11 2014
    Anaheim, CA
    B9 S4 lowered on eMMOTION lowering springs with Vorsteiner VFF103 20x9 ET35 and 255/35/20 tires.
    Apr 14 2017
    Socal
    Dang looks way good with those rims
    Feb 11 2014
    Anaheim, CA
    Another local B9 S4 customer running eMMOTION lowering springs & rear sway bar. Pictured with Neuspeed RSe102 20x9 ET40 wheels.
    Feb 11 2014
    Anaheim, CA
    B9 S4 that received our stage 1 suspension package featuring eMMOTION lowering springs and rear sway bar!
    https://www.emmanueledesign.com/coll...nt=41250085706
    Feb 11 2014
    Anaheim, CA
    Some updated photos of STICKY RICE's S4 lowered on eMMOTION springs!
    Veteran Member Three Rings VipinLJ's Avatar
    Nov 23 2016
    Illinois
    Blasphemy! S4!! Not S3. Hehe. Looks great btw.
    2018 Audi SQ5 Prestige - Matador Red, DAP, S Sport pack, 21” V design, CWP, WWP
    2017 Audi A7 Prestige - Glacier White, DAP, Sport pack, 20" BOP, CWP
    2020 BMW 330i xDrive
    Mar 29 2012
    B9 S4
    California
    Thomas is probably thinking of my old car.
    Nov 23 2016
    Illinois
    I know! Couldn't resist pulling his leg though!
    Feb 11 2014
    Anaheim, CA
    Quote Originally Posted by VipinLJ View Post
    Fixed!
    Too used to STICKY RICE & S3 going together. Like peanut butter and jelly
    May 03 2017
    For a flush look with OEM BO wheels, what spacers do you recommend?
    Feb 11 2014
    Anaheim, CA
    Looking to save some $$ on your suspension upgrades? Take advantage of our suspension package pricing, with reduced cost for spring & sway bar combos!
    https://www.emmanueledesign.com/coll...nt=38748795466
    Active Member One Ring serge25's Avatar
    May 26 2018
    Mexico
    Mine didn’t came with the bump stops...not even with the bottle opener... so sad...
    Nov 13 2016
    Houston, TX
    Would this kit make a difference in a sport suspension equipped a4? Thanks
    Sent from my SM-N950U using Audizine mobile app
    Jan 28 2018
    Ontario, Canada
    I'm just curious to understand how can the ride quality be very close to stock when it sits 1 inch lower and the spring rate is stiffer?
    I'm on the fence of buying but afraid of potholes and general rough roads in Canada.
    May 26 2018
    Mexico
    Quote Originally Posted by speedyp View Post
    Hi. I will share you my personal opinion.
    I recently installed them, tried for 4 days, they definitely accomplish the lowering purpose without a problem, they will low more in a couple weeks.
    Mine don’t come with the front shocks, I had to cut them as EMD gently explained to me.
    Well, I live in Mexico and we have horrrible streets, but many in optimal condition. Having that said, the OEM springs experience was very soft but a bit bouncy as well, the EMD springs on rough streets is very nice, but a bit noise in the left bottom on rough streets, just a bit more stiff but as good as the original. Passing through potholes feels pretty much the same. The rear part yes is a bit bouncier, not noticeable if you don’t “fly” through bumps. You gotta be a lil bit more careful cause a more sporty suspension mod.
    Jun 28 2018
    Augusta, GA
    For those that have installed the springs and/or sway bar, what did labor look like for them (hours/cost)? Thanks!
    Senior Member Two Rings dbuxton13's Avatar
    Apr 20 2016
    Germany
    Quote Originally Posted by Alexdsheff View Post
    Bump because I have the same question.
    Also one more: is an alignment necessary for an S4 with adaptive suspension?
    B9 S4
    Aug 26 2018
    Southern California
    Any photos of a B9 Allroad with eMMOTION springs? Would love to see how it looks. Thanks!
    Apr 10 2021
    So Cal
    Just installed my emd springs and everything is as advertised. The only thing ive noticed is a ever so slight reverse rake in fender to wheel gap. Ive only drove about 20-30 miles so far so they may settle and even out, but has anyone else experienced this? I have the b9 a4 with sport suspension
    Apr 10 2021
    So Cal
    Quote Originally Posted by LTboogz View Post
    My post was probably a little premature lol ive already noticed the front lowering to even out, just needed time to settle. Love these springs as far as drop and comfort they’re exactly what i was looking for. I will be getting the rear sway bar when they’re back in stock. Thanks EMD
    Apr 03 2022
    AB, Canada
    I'm a total noob so feel free to correct me. I am looking to lower my A4 b9 with sport suspension with a build date of 09/2016. I have heard the front struts are different sizes depending on the build date. Would you recommend trimming the front struts on sport suspension or is it only recommended on the factory base suspension?
    If they do need to be trimmed, how do I figure out how much for the front and rear?
    Junior Member Two Rings
    Aug 21 2016
    '22 A4 Allroad , '24 A4 Sedan, '22 Boxster GTS 4.0
    Burlington On Canada
    Quote Originally Posted by Simias View Post
    X2
    '24 A4 Technik, '22 A4 Allroad Technik
