Already brought the car into a local (Chicago) shop that seems legit, Wizard Werks, but thought I'd see what you guys think.
Started with the engine running rough and "eating" about 1.5 quarts of oil per 1000 miles. At this point it would go away if I pushed the clutch in.Putting in heavier weight 10w 40 oil seemed to help
Later it developed into a really bad vibration around 2800 rpm and if I pushed the clutch in all the way I'd get a different sort of noise., making me think there was also a throw out bearing/pressure plate failing. Also shifting into 3rd had to be delicate and slow or else the teeth would mash. But maybe this could also be because the engine was vibrating?
They don't think it's the infamous timing chain issues since the engine isnt misfiring. Anybody run into something similar?
