Results 1 to 6 of 6
    Oct 24 2016
    Coding Central Convenience Problem
    Patient is a 2005 A4 1.8tq manual.
    I have been trying to code the cetral convenience module 46 to eliminate the locking
    at speed, door alarm and Canadian DRLs. I can connect to the module both with authorized
    VAGCOM and VAG401 tools. I can read the existing coding fine but when I enter a new
    value by either VAGCOM or VAG401 it is not accepted? Any thoughts on how to narrow
    down why the FLASH in the Central Convenience module won't get written?
    There are no codes with the CC module.... Could the module itself be the problem.
    cheers, Mike
    Jun 19 2012
    06’ A8L 4.2L, 04' 330CIC, 91’ Corrado 1.8T, 10' Q5 3.2L,
    Long Island, NY
    Not that this is the solution, but I've had some trouble coding modules. Sometimes I will enter a value I know to work, but is different than what is written. Flash that then try to flash the value you want.
    Sep 08 2016
    Grover Beach, CA
    Doug, when you say that your enter a known value, is that the value that the PR codes give for the Login but when you try to code it doesnt code properly? I need a little clarity, i am having issues coding a module. Thanks!
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Are you following the correct procedure detailed here:
    http://wiki.ross-tech.com/wiki/index...Comfort_System
    2019 SQ5 Prestige
    Jan 24 2010
    Paramus,NJ USA
    What is the value you have and what do you think the new one should be???please post it i will let you know if you have the right coding or not.
    Ziddy Autowerks
    Sep 08 2016
    Grover Beach, CA
    So its not a Convenience module but the ABS module. The login should be 09395, and the code should be 04495. 3.0L manual with the FN3 brakes. i can log in but the code doesnt work, i get a communication issue. It my fault. i dont have VCDS so im attempting this with a VAG401. I cant change the workshop code from 00000 to anything else and i think that is my problem. Doing more research now, may have to buy a cable. later though, at least i have a speedometer again.
    -E
