Results 1 to 9 of 9
    Feb 13 2017
    IE
    Horrendous smell when I use windscreen washer
    Noticed recently that there is an awful smell, something like bad eggs or dead rats coming into the car each time I use wind screenwasher fluid. Having recently bought the car, I put in Autoglym washer fluid on top of existing water that was in there. Now it's rancid. The resevoir itself smells OK, but I presume the stink is coming from the pipes (which I cant smell).
    What is the easiest and best way to clean these out? I would like add in a formula of something and blast it through but what is the safest liquid to use without damaging the pipes or paintwork?
    Audi A4 S Line 2015 TDI
    Automatic
    Scuba Blue
    Jun 04 2016
    A
    Have you opened the reservoir and put your nose in to have a sniff?
    chances are, it could be the soap… I've seen that happen before… mixture of stale soapy water with new soap etc.
    If it is, why don't you just stick the hose in the reservoir… fill it up till it overfills and replaces the contents with fresh water inside and give it a try?
    Feb 13 2017
    IE
    Quote Originally Posted by doublespeeded View Post
    yeah i stuck my snout in there already. funny thing is all i smell is the regular wind screen washer scent. this leads me to believe that the foul aroma might be isolated within the pipes to the water jet. i wonder would bleach mixed with water help kill off the smell / bacteria....
    Automatic
    Scuba Blue
    Veteran Member Three Rings wabbit23's Avatar
    Mar 20 2011
    2011 Avant Quattro & 2010 Jetta TDI
    San Diego, Ca
    Quote Originally Posted by alsiet View Post
    Do NOT use bleach in there. Even in diluted form it can corrode metal and some plastics pretty quickly. Just flush the old stuff out with new stuff and call it a day.
    Mine- 2011 Avant Quattro- Premium Plus w/ Sport Package- APR Stage 2/ SPM Downpipe/ AFE Prodry S/ R8 Coilpacks/ ECode HFIP/ ECode Intercooler Piping kit/ 20% F & 15% R tint/ Dipped Parts & Vagcom stuff
    Hers- MKV Jetta TDI- Matte Black VMR V710's / H&R OE Sports/ Koni FSD's/ Dipped parts everywhere
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    x2 don't use bleach.
    The sensor and other metal parts are sensitive. Even certain types of windshield washer fluid will coat the sensor and have it malfunctioning thereafter.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Feb 13 2017
    IE
    Thanks for all the help guys. I flushed it out anyway and put more clean water in. Smell is disappearing with every flush. Be good as New soon. Thanks again
    Automatic
    Scuba Blue
    Jan 19 2016
    1997 BMW M3 w/ CES Stage IV Turbo, 1999 BMW M3 vert
    Orlando, FL
    Maybe try adding poopouri in there....should take care of that smell right away
    1997 BMW M3
    CES Stage IV (651rwhp/615rwtq @ 24 psi)
    2020 S6
    Premium Plus, Black optic, performance exhaust
    2013 Audi A4 (sold)
    Prestige package, S-Line, 6-speed |IE Stage 2 | IE Performance Downpipe | S4 exhaust swap | ECS Luft-Technik intake | ECS Luft-Technik FMIC | RS4 grille | ECS SSK | ECS Trans/Diff Inserts |
    Feb 03 2017
    NH
    Quote Originally Posted by Zach L View Post
    I learned that the hard way with orange rain-x stuff. Had to use a chainsaw file to clean the probes on my B5.
    Senior Member Two Rings rdenivo's Avatar
    Jan 05 2016
    2011 VW Tiguan
    Quote Originally Posted by twixinthemix View Post
    I used rain x-once and had to get the sensor replace. It's the cheap stuff for me now.
    2015 A4, Scuba Metallic Blue, Eurocode Front and Rear Sway bars, Chrome delete, Partial Air Leather FBSW, Black S-Line and Audi badges, 19" Satin black 10 spoke rims
