Originally Posted by
Peter1.8t
18x8.5 et35 should clear the front brakes with no issues unless it's a weird spoke design. At most you'd need a 10mm spacer, probably would clear with a 5mm spacer. 1" is too damn big.
this is typically correct. there are 2 things that need to be considered outside of offset and wheel width and tire selection: first, the spoke shape (or x-factor). second, the barrel shape. Some spoke designs and barrel shapes cause contact on the caliper. wheel spacer sufficiently large and fender rolling will solve the spoke issue. Barrel shape may not be able to be resolved unless it just so happens that the shape of the barrel allows greater clearance at a different offset.
you gotta measure what's contacting, add at least 1mm for flex (keep in mind new pads will move the caliper out as well). If it's the barrel, you're probably hosed.
this is super simple stuff than any knucklehead in the industry should well know. And if you were sold these by a wheel shop that told you they would fit, you 100% have a claim in small claims court regardless of their policy.
