Hello,
I've been searching the forums for this...
I have a 2015 8.5 Allroad. I bought used S5 peelers 19by9 with ET 33 -- Do I need spacers? The original wheels 18by8 are ET 26 -- I have been told they will fit, but to put the wheels in the right place for the suspension the calculator says they will be 20mm closer on the inside, and 6mm further out on the outside. Should I split the difference and use 8mm spacers? That would net 12mm closer on the inside and 14mm on the outside. Or would 6 or 10mm be better? Thanks!!!
