Results 1 to 40 of 41
    Sep 17 2005
    Fremont, California
    Now Available: Dynamic+ Lowering Springs for B9 Audi A4/Allroad!
    After months of testing at 034Motorsport, Dynamic+ Lowering Springs for B9 Audi A4 & Allroad are finally available!
    Dynamic+ Lowering Springs were engineered and tested in-house at 034Motorsport to deliver superb ride quality and optimal handling performance. Designed to as a true no-compromise solution, Dynamic+ Lowering Springs provide an aggressive yet functional stance, and reward drivers with precise vehicle control and OEM+ comfort levels.
    Dynamic+ Lowering Springs were thoroughly evaluated on the street and track on 034Motorsport's B9 Audi A4 Development Vehicle, and by independent Audi enthusiasts before release. The selected spring rates, unique dual-rate spring design, and ride height are the culmination of months testing - thousands of miles of commuting and countless track days - resulting in a lowering kit that is perfectly matched to the factory dampers.
    Each set of Dynamic+ Lowering Springs is manufactured in the USA at an ISO 9001 certified facility, and tested to 034Motorsport's exacting specifications to ensure they deliver unmatched levels of handling performance. These springs are the ideal suspension solution for the discerning Audi A4/Allroad owner who desires to lower their vehicle and enhance their driving experience.
    Features:
    • Improved Handling Performance & Chassis Dynamics
    • Reduced Body Roll & Understeer
    • Superb Comfort & Ride Quality
    • Compatible with Audi Adaptive Suspension
    • Lightweight, High-Strength Construction
    • Shot Peened & Powdercoated
    • Made in USA at ISO 9001 Certified Facility
    Ride Height:
    • B9 Audi A4 Base Suspension
    • Front - 2.0" Lower
    • Rear - 2.0" Lower
    • B9 Audi A4 Sport Suspension
    • Front - 1.1" Lower
    • Rear - 1.1" Lower
    • B9 Audi Allroad Suspension
    • Front - 2.2" Lower
    • Rear - 2.0" Lower
    Effective Spring Rates:
    • Front - 365 Pounds/Inch
    • Rear - 490 Pounds/Inch
    Fitment:
    • 2017 - Present Audi A4 (B9)
    • 2017 - Present Audi Allroad (B9)
    • Please Note: Compatible with Base, Sport Package Equipped, and Audi Adaptive Suspension Equipped Vehicles. We recommend trimming the front bump stops by 10mm on Base Suspension A4s and Allroads.
    Click Here to Order!
    Veteran Member Three Rings VipinLJ's Avatar
    Nov 23 2016
    Illinois
    What happens if you don't trim the bump stop? My knowledge on the mechanicals of suspensions and bumpstops are pretty bad. Sorry.
    2018 Audi SQ5 Prestige - Matador Red, DAP, S Sport pack, 21” V design, CWP, WWP
    2017 Audi A7 Prestige - Glacier White, DAP, Sport pack, 20" BOP, CWP
    2020 BMW 330i xDrive
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by VipinLJ View Post
    You might run into the bump stop sooner than necessary if it's not trimmed. Since our springs are a higher rate than stock, bottoming out is not an issue, but they are designed for the shorter bump stops that are used on the Sport Package front shocks.
    Since you have the Sport Package, your bump stops do not need to be trimmed at all. Only the Base A4 & Allroad have slightly taller factory bump stops. Hope that helps!
    Veteran Member Three Rings emnahum's Avatar
    Jan 10 2014
    Looks good. The Allroad especially cries out for a drop.
    2015 S4, P+, 6MT, Mythos/Black Nappa, SD, ADS, B&O, BO, Tech, Opticoat, Xpel Full Hood, 034 Transmission Mount, EC Sways & Links, CR-15
    Previous: 2004 A4 Avant 3.0 V6, 1995 90 Sport Quattro, 1984 4000 CS Sport Quattro, 1981 4000 5+5
    Nov 23 2016
    Illinois
    Quote Originally Posted by 034Motorsport View Post
    He he I got it. And mine is the stock non-sport suspension. So I guess I'll have to trim it.
    May 03 2016
    These springs look fantastic on the Allroad and will definitely be going on my mod list. Perfect amount of low for me.
    I suppose instead of trimming the stock bump stops one could always order new OEM Sport Package Bump Stops to ise instead. Just in case one needed to go back to stock one day.
    Nov 23 2016
    Illinois
    Quote Originally Posted by Fantasiamon View Post
    And where can I buy the sport suspension bump stop from?
    May 03 2016
    We need to dig up a part number somewhere first. Dealership should be able to order from there. If we catch them on a good day the Parts Department might even help find the part number for us.
    Nov 21 2016
    St. Paul/Minnesota
    I seen them on Europrice.us under the Sport Springs, front and rear $93 + S/H.
    2017 Audi A4 Premium Plus - Mythos Black - Tech & Cold weather pack - H&R sport springs - 50% 3M tint
    Dec 17 2016
    San Francisco Bay Area
    Ugh. Y'all made me log in to ETKA. :)
    Front
    Allroad: 8K0412131E (81mm)
    Sedan/Sport: 8K0412131F (72mm)
    Rear
    Allroad: 8W0512149B
    Sedan: 8W0512149A
    May 03 2016
    Quote Originally Posted by wdimagineer View Post
    Front
    Rear
    Allroad: 8W0512149B
    Sedan: 8W0512149A
    I'm still getting used to the game. EKTA looks like a great resource I'm going to start playing with. Thank you.
    Dec 17 2016
    It is a powerful resource but caveat emptor. The real ETKA is available only to authorized folks, including independent techs who pay for it. There are free sites that do offer parts data, typically sourced from legit users, but they are not always up to date and may have inaccuracies. Always gut check with someone who has access prior to committing funds.
    Veteran Member Three Rings audinator's Avatar
    Nov 17 2005
    B9S4, 91 CRX, 85 CRX, 17 Thundra
    SoCali
    These springs are looking nice on the B9's!
    2018 B9 S4 Daytona Gray | Rotor Gray
    . . . and many other Audi's over the years . . .
    May 03 2016
    Discovered that upon further review. Login creds were a no go. But yes, I've had some successes with looking up part numbers through some sites I've navigated to. Sometimes all it takes to find some is by googling part numbers in general.
    Anyway, the springs look great and will be looking to place an order for sure.
    Nov 23 2016
    Illinois
    Thank you so much for all the info guys
    Front
    Rear
    Allroad: 8W0512149B
    Sedan: 8W0512149A
    So it looks like both the sport and non-sport version of the sedan have the same bump stops?
    Established Member Two Rings Four rings fan's Avatar
    Sep 10 2016
    Florida
    I'd also check the part #s for the sport pkg dampers vs the non sport dampers. If the part #s match then all is good. If not by installing shorter bump stops you may be exceeding the range of travel of the non sport dampers when you install lowering springs. Didn't see any one mention this so just thought i'd throw it out there. Food for thought.
    2018 S6 Mythos Black Prestige
    May 03 2016
    Quote Originally Posted by Four rings fan View Post
    True but 034 mentions trimming the bump stops by 10mm for the springs. If you look at the above numbers they seem to add up to about 10mm difference. So should be ok? I need to do some more cross referencing of part numbers and the like still but I hear what you're saying.
    Sep 17 2005
    Fremont, California
    Thank you for the orders and interest!
    Just to clarify, there are a myriad of different part numbers (14 of them from what I can tell) for the front shocks based on build dates and option packages. The Base A4s and Allroads we have seen here have come with 81mm front bump stops, and the Sport Package A4s (including ours) have had 72mm ones. We recommend trimming the front bump stops 10mm on the Base A4 and Allroad.
    Nov 23 2016
    Illinois
    I didn't get this. Is that good or bad or doesn't matter? I'm guessing it's bad. But how will it affect my car on the road? Sorry but I'm a big noob.
    So leave the rear ones as it is and only trim the front ones? I'm asking cuz in the bump stop thread, Emmanuelle says it's ideal to trim off 1.2" from the rear as well. And their front bump stops are like 1.039" shorter than the ones stock on the standard A4. Their standard A4 has been lowered by about 1.6" whereas the 034 will be 2.0" lower than stock. Basically, my issue is that post install of the lowering springs, my car shouldn't bottom out or feel like it is hitting the bump stop or anything.
    Sucks when you don't know much about suspensions
    Sep 17 2005
    Fremont, California
    Thank you for all of the orders! Looking forward to some more installed pictures.
    Yes, we only recommend trimming the front bump stops. Our recommendations are based on our spring rates and ride height, which differ from other manufacturers. Hope that helps!
    Nov 23 2016
    Illinois
    He he absolutely. Followed your orders :D love the springs. Perfect ride quality. Handling is on point. If only the weather was better.
    Sep 17 2005
    Fremont, California
    Thank you for the interest and orders! Dynamic+ Performance Lowering Springs for the 2017+ Audi A4 & Allroad are in stock and ready to ship.
    Mar 22 2017
    Audi A4 B9 / BMW X3 / Infiniti QX60
    Portland OR
    Ordered mine, arriving tomorrow
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by mac0yski View Post
    Thank you for the order! Looking forward to your feedback.
    Mar 22 2017
    Portland OR
    Love the ride and looks really good. Works pretty good with oem shocks. Really made a big difference, no more ugly wheel gaps.
    Sep 17 2005
    Fremont, California
    Looking good! Thank you for the pictures! How do you like the handling?
    We have plenty in stock ready to ship! Make sure you take advantage of the free shipping we have going on for a limited time!
    Mar 22 2017
    Portland OR
    Handling is superb! I can now make quicker turns with more confidence and there's no more feeling of floating with a high ride height. way way better. You guys nailed it! Also wanted to thank you guys for the great customer service, I had a bunch of questions before purchasing this and you guys gave me all the information needed. Quick detail response is the best.
    Sep 17 2005
    Fremont, California
    We sincerely appreciate the kind words and feedback! We always strive to produce the best products on the market! Glad to hear that you guys think they're great also.
    Sep 17 2005
    Fremont, California
    Thank you for the orders!
    Established Member Two Rings AXARUNNER's Avatar
    Jan 17 2017
    2017 Allroad, 2013 Aston Martin V8 Vantage S; 2016 Audi TT Roadster
    Glen Ridge, NJ
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by AXARUNNER View Post
    Looks awesome. How are you liking the handling differences?
    Jan 17 2017
    Glen Ridge, NJ
    The springs really made a huge difference. I actually hated the vague floaty-ish handling of the OEM set-up. The springs along with the 255/40 19 Michelin tires have transformed the car from awful to awesome handling wise. The APR tune has made the car wicked too.
    Sep 17 2005
    Fremont, California
    Thank you for the pics and feedback! It sits quite nicely. When you have a moment, we would really appreciate it if you can leave this review on our product page if you haven't already. Many Thanks!
    Sep 17 2005
    Fremont, California
    Sep 17 2005
    Fremont, California
    Anymore reviews/photos?
    Sep 17 2005
    Fremont, California
    Need some car P0rn to look at? We got you cover ;)
    ARTURO'S SCINTILLATING SPRINT BLUE B7 AUDI RS4
    Sep 17 2005
    Fremont, California
    Thank you for all the orders!
    Sep 17 2005
    Fremont, California
    Take a closer look at 034Motorsport's product philosophy, and see what goes on behind the scenes to create and deliver 034Motorsport Go Fast Parts.
    Nov 09 2017
    2017 A4 Honda Crz Acura TL-S
    missouri
    question for the a4 with non sport suspension.. the ftg ratio is around 27 3/4 front and rear.. does anyone know what the FTG is after installing the 034 springs on a A4 17-18 non sport suspension?
    Sep 17 2005
    Fremont, California
    B7 A4 with a 2.7t swap?!
    RYDER'S 2.7T SWAPPED B7 AUDI A4
