ECS Tuning's transmission mount insert kit offers a more engaging driving experience, with crisper throttle response and reduced driveline slop without increasing cabin NVH.
Both the ECS Tuning performance rear differential mount insert kit & performance transmission mount bushing insert were engineered in-house by our industry leading R&D department. Upon countless hours of research and testing we establish the best possible design for minimizing driveline deflection while retaining the vehicles everyday driving comfort.
Key Features:
- Reduction in transmission movement
- Billet & black anodized 6061-T6 blacking plate for durability and corrosion resistance
- Polyurethane bushing insert to reduce drivetrain deflection while keeping noise vibrations associated with such modification to a minimum
- Increased drivetrain rigidity and response
- Long-term testing performed on multiple vehicles for real-world qualification
- Included hardware to replace the factory torque-to-yield bolts as recommended by Audi
- Being a relatively simple process, if you're mechanically inclined you should have no problem installing the mount in your own garage in under 30 minutes. For assistance with installation, please see our in-depth installation PDF available under the Installation tab.
Insert Rigidity & Response
Fits:
Audi B9 A4 2.0T 2017+
Be sure to check out our -----> Installation PDF <-----
Jason
