Originally Posted by
whiped
Don't quote me on this as I am not positive but I believe it is an 80mm TB vs the 70mm stock one.
Should give you better throttle response and maybe 5-10 whp?
Doubtful that the larger throttle-body would add 10whp. Porting the stock one has shown minimal gains. Same with porting the stock blower.
Now, smoothing the transition between the throttle body and the rotors of the blower, potentially providing less turbulent air coming in, that could probably pick up a few (could potentially drop IATs by a few degrees).
Neither the turbulent air nor the volume on the atmospheric side of the blower have ever really been a constraint. Looking at logs proves that.
It's always been IATs. Always will be until someone does something significantly different.
Summed up, $2k+ in additional hardware for a possible 10whp over a standard DP setup = not worth all the hype.
Hopefully, I'm wrong. Unfortunately, nearly a decade of professional experience in the industry, trap speeds of the test mules, and general gut feeling on APR states otherwise.
-DL
