Results 1 to 8 of 8
    Jun 04 2012
    Greenville NC
    Another question after testing valves
    Yesterday I did a test to see if my valves were bent; covered the 5 valves with water, sealed off the ports and introduced pressurized air to look for bubbles. I noticed small amounts of bubbles but not a tremendous amount. My thoughts are a few valves aren't seating 100%, but they aren't bent necessarily. The question is whether I should reseat the valves, being low on money after the timing chain overhaul should I sink in another 2/3 weeks in time taking apart the heads and lapping the valves, or leave it as is? I mean they should hold compression, so should I go through this long process or not?
    Established Member Two Rings slineb7's Avatar
    Jul 16 2010
    2016 Escalade EXT, 2017 A8
    Tampa
    Although I'm not an expert in the field of valve seating and compression, I'd say if you're already there, do it right. These are high performance machines that require precision. The last thing you want to find out is that you have to tear off the heads again later to fix it.
    Do it right or do it twice...
    2007 RS4 Daytona Gray | KW V3 | More to come...
    Nov 12 2015
    Oregon
    I'm no expert either, but if you have the heads off, it's a no brainer imo.
    My build log
    Jan 29 2017
    B7 RS4, B15 Sentra Spec V
    San Antonio, TX
    New head gaskets, possibility of needing the heads milled, seats may need more than lapping...
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    get a lapping done.
    Jun 04 2012
    Greenville NC
    I have new head gaskets ready to be installed, and taking the heads over to a machine shop to get them professionally pressure tested. If work needs to be done, I'll let them do it all and clean up the ports while they're at it. When it's all said and done, going to have a nicely overhauled engine on my hands, can't wait!
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    Quote Originally Posted by q_dubz View Post
    get a lapping done.
    this.
    If you have the heads on the work bench you can do it yourself. places like auto zone sell lapping compound.
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    May 29 2010
    2004 Audi S4, 2008 Audi RS4 Ti
    Phildelphia / Auckland
    Before you lap, the stem-to-valve guide clearance needs to be checked. If it's in excess of the service limit (0.0031"), you'll need to replace the guides then clearance them to new spec.
