Results 1 to 7 of 7
    Active Member Two Rings dre731's Avatar
    Jan 08 2010
    brooklyn
    Stiff steering wheel.
    Hey guys. Starting yesterday my 2012 a4 started acting up. Steering is very stiff as if I'm driving 50 mpg when I'm barely going 5 mph. Has anyone had this problem? Please let me know what it might be an what the solution is. TIA
    Senior Member Two Rings ranchos's Avatar
    May 05 2014
    United States
    servotronic fuse, relay, or maybe busted hose:
    http://www.audizine.com/forum/showth...eering-failure
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    I have had this VERY issue. It felt like power steering was cutting out almost, totally at random. Turns out there is a universal joint down low in the steering column that is very exposed, especially if you no longer have your belly pan (like me) and this joint can attract a build up of rust and corrosion. Cleaned it up nice and it was like I had just put a new power steering pump in car.
    2016 S3
    Instagram- @Thisisastickup
    Jan 08 2010
    brooklyn
    Quote Originally Posted by ranchos View Post
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    Quote Originally Posted by b6Hate4 View Post
    I had this same issue as well, it will seem to bind at spots during the rotation of the steering wheel, at other spots it is more normal.
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
    Jan 08 2010
    brooklyn
    Dropped the car off at the shop. Waiting for a phone call
    Jan 01 2012
    2004 A4 Avant
    CO
    this happened to me also. rabbit chewed through the servotronic valve wiring. butt spliced the wires back together and been fine since.
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
