Results 1 to 22 of 22
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    B8 S4 Cluster (red) to B8 S4 cluster (color) swap
    I'm looking to swap my gauge cluster to rid myself of the red center display, I can't read that thing at night and it's just subpar. I have done a bit of searching and have seen major upgrades to B8.5 with trim and even to S5, all more complicated than I want.
    Mine is direct, B8 to B8 both S4 gauges. Guessing I need to have CP removed at least, but is there anything else? I have read that maybe the column stalks might need to be updated, can anyone confirm? Vagcom settings maybe?
    Two more questions, can I replace the smaller non Nav display without upgrading to the full MMI? Lastly, anyone have the vagcom codes to make the white number climate controls work in place of the red number? I will be doing the full MII 3G+ later this year, just want to play a little in the mean time with the cluster, climate, and 7" display screen.
    Thanks in advance. oh, and mileage is within a few thousand so I'm not worried about that.
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Rich, there's a thread floating around here on how to update that cluster to color. You will need new wheel stalks to enable the new dash/display functions. I'll see if I can find it.
    Here's a link to the coding for climate swap: http://www.audizine.com/forum/showth...1#post11972244
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Here's the link to color display retrofit: http://www.audizine.com/forum/showth...1#post11851028
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    I personally had this done with a cluster I found on eBay then I had Tom over at SpeedoSolutions do all the programming/Immobilizer work needed! http://www.speedosolutions.com
    http://www.speedosolutions.com/Audi-...ding_p_90.html
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Jan 20 2017
    RS7
    New Hampshire
    Quote Originally Posted by avantagg View Post
    Thanks! I did find this thread but wasn't completely sure on the stalks, seems most the threads are doing the complete swap. I'd like to jump in just not head first since I've only had the car for about a month. Just keeps getting deeper to make these somewhat subtle changes, too. Guess I need to find those now, starting with finding the part number.
    Jan 20 2017
    RS7
    New Hampshire
    Quote Originally Posted by stereojorge View Post
    Guessing you're local to them? I found them and they appear to be selling CP removal online, says to call them. Not sure how they could do that remotely. Guess I'll need to do everything together to prevent more than one charge for CP removal.
    Oct 15 2013
    Tampa, Florida
    Quote Originally Posted by Ford Prefect View Post
    I actually lucked out and the gentleman Tom was vacationing minutes away with his family in Florida, so we had a garage day!
    Jan 03 2013
    Baltimore
    I did the same swap on my A4. I found a cluster, shipped to Tom and told him the mileage I needed. Set it to a figure greater than what my car was and swapped it in once my car reached that figure. I then went to the dealership to remove CP. I also added the stalk with additional buttons. Couple vagcom changes and all done.
    Sent from my Pixel using Tapatalk
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    Quote Originally Posted by elscotto80 View Post
    So you have the color display working with either Concert or Symphony radio? Everyone I've seen convert from red to color so far has the MMI navigation system so I figured MMI might be a requirement for it to work. If it's possible, I have VCDS and could do the coding found in the MMI retrofit thread. What radio do you have in your dash?
    If so, how much did Tom and the dealership charge for those services? Thanks!
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Jan 20 2017
    RS7
    New Hampshire
    +1 for the questions above. I am doing the MMI swap but wanted to change the gauges first.
    Oct 15 2013
    Tampa, Florida
    I did JUST color DIS cluster swap while still having Audi Concert on my old B8
    Jan 20 2017
    RS7
    New Hampshire
    Was just playing around this morning and put the gauges in, secretly hoping CP was a myth. Want to verify since indeed it went into safe mode. What I saw was that nothing worked, tach, speedo, back lights. It showed the mileage and red "safe" above. The warning lights did light, but agin no back light. Just want to make sure that is what safe mode does (doesn't seem very safe) before wasting $130 bucks at Audi.
    Thanks in advance.
    Oct 15 2013
    Tampa, Florida
    Thanks in advance.
    Yes sir!
    Jan 20 2017
    RS7
    New Hampshire
    Yes sir!
    With lightning quickness! Thanks for the fast response!
    Feb 23 2010
    Austin, TX
    No more red in my 2010 A4. Swapped in a color DIS cluster and B8.5 climate control while still having Audi Concert radio. Will probably upgrade later to MMI 3G+ or just the B8.5 Audi Concert (to have matching silver knob and gloss black inlay).
    Jan 20 2017
    RS7
    New Hampshire
    Quote Originally Posted by Zach L View Post
    Nice!
    How much component protection removal for you? Did the shop understand what you wanted the first time?
    Feb 23 2010
    Austin, TX
    A typical shop can't do component protection removal. It was the local dealership.
    I did the climate control install and coding for that right before I brought it in because it won't blow air until component protection is removed.
    They scheduled me for a day when their most senior technician was there. I assured them they wouldn't need to code anything, but they said they'd have to do coding. They insisted I bring the original parts in with me, so I did. That's not necessary either but whatever.
    I got the car back and everything works, but I did have to recode the modifications I had done previously to the central electronics module like the needle sweep, remote windows, etc. They messed with more than they should have but everything is working well now. Although I think it probably took them longer, they only charged me for an hour of labor.
    Jan 20 2017
    RS7
    New Hampshire
    Thanks. I meant dealership. I called one and they were thoroughly confused on what I was asking. Everything I've read has said about an hour.
    I want to make the same change as you, have the stuff. I also have whole MMI 3G+ minus the fakra cables. Torn of if having CP removed twice is worth it.
    Feb 23 2010
    Austin, TX
    I honestly would start with something simple that they perceive as easy, especially if you're getting push back and confusion from them. It might be worth an extra hour ($140) versus them not doing it at all.
    It also will help if you have some kind of a relationship or even just your name already in their service database. I do all my own maintenance/repairs, but I had gone to this dealership one time in the past for a pre-80,000 mile oil change (I thought it would help with oil consumption warranty if I ever needed it). So when I called the service advisor I think it helped that he could bring me up in their system and not think I'm just some random guy trying to pull something on them. Service advisors are actually really ignorant with technical know-how and understanding, and 90% of technicians can't think outside of what the computers tell them exactly to do.
    These type of jobs are odd balls and not money makers. From a business standpoint they don't make sense, so I'd kiss ass and make them want to help you.
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Just wanted to give a shoutout for that link! I've been looking for someone to do an immobilizer defeat and hadn't heard of speedosolutions before.
    Going to give him a call tomorrow
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Established Member Two Rings audi5inline's Avatar
    Jan 10 2013
    Audi RS2 avant
    The Netherlands
    Would a b8.5 cluster work in a b8 ?
    '11 Audi S4 3.0TFSI
    '95 Audi RS2 avant powered by Porsche
    Jan 20 2017
    RS7
    New Hampshire
    Quote Originally Posted by audi5inline View Post
    I think some trim pieces need to change, the bezel or whatever it is. But some have done iirc.
