Results 1 to 4 of 4
    Apr 06 2014
    Ca
    Dead battery need advice
    So the battery died and I used a Ctek and fully charged it. Everything else is fine except for the MMI interface which is not displaying anything on the screen.
    Anyone come across this issue?
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    You may need to do an MMI reset. I can't recall the buttons to push (3) simultaneously, but it's in the manual. Might also want to check your fuses. Otherwise, the only time I've had my screen go dark was when I had to replace it in my 2009 A4 (non-MMI). I was told that the screens die quite often and are a weakness in the system. Cost me around $500 CDN for the screen that I bought from the dealer and had an indie install it for free.......
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Apr 06 2014
    Ca
    Hey guys I don't have a setup button on my MMI interface nor did I find anything in the manual
    Active Member One Ring Glenn4.2's Avatar
    Feb 19 2017
    Ontario, Canada
    Don't know if this will fix a blank screen but
    http://mr-fix.info/audi-mmi-force-restart-reboot-2g-3g/
    Red leather on Ibis white 2011 S5 6MT | B&O | Drive select and Sport Differential | Carbon Fibre Trim | Eisenmann Exhaust | H&R sport | RS5 Grill
