Results 1 to 7 of 7
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    3.5 Gallon of E85 - Pump GIAC File 93/Mix Comparo
    Holds 21 degrees of timing up top, zero knock. 93 timing curve with knock for comparison. I can really feel the difference up top. GIAC Stage 2, AWE S/C Pulley, ECS Intake, Ported + Polished TB, AWE Cold Front, Cat Back
    Boost, Bleed, and timing for E85 Addition log. Its hitting 18.2 psi up top. Boost is actually exceeding requested some places down low, causing the bleed to have higher duty. I realize that is not the actual AFR with the mix, I just multiplied lambda by the gas scale as its easy to visualize on the graph.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Jul 21 2004
    South Florida
    Yeah, same as me. Running e85 fixes their timing issue but the odd boost curve remains.
    It worried me since I was running 93 octane as we dont have much e85 around here. I got the GIAC file in hopes to try their dual pulley tune when it comes out and then I learned that two of the big beta testers were both pretty much beta testing e85 90% of the time (please correct me if I'm wrong fellas). This was making sense when I looked at the logs because it didnt seem right for 93 octane at all. I decided to just get a refund because file changes can take time and I didnt want to be stuck with something that doesnt work for me. GIAC was really cool about it though and very professional throughout the process.
    Mike
    2018 Audi S5
    Gone-
    Jan 26 2015
    2017 XC90, a workbench
    CO
    I'd just like to say that for the record, I hate you guys at lower elevations. I had to go DP just to hit 18psi. With that said. Good logs.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    I really need to toss in a few gallons of E85 with my next fill up...
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Jul 28 2009
    Philadelphia PA
    Quote Originally Posted by Vogz View Post
    Do it! I was surprised how much the pump file woke up.
    c8 a6 allroad
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    Quote Originally Posted by rtl5009 View Post
    no E85 around here so sorry if this is a dumb question, but why wouldn't you use the race file?
    when i was around E85, GIAC said i could run the race file with about 5 gallons of e85
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Veteran Member Three Rings FromRagsToS4's Avatar
    Jan 23 2017
    Idaho
    I put 3 gallons of E70 (winterized E85) in a few days ago and I really liked how it pulled up top!
    2014 S4 Premium Plus/Glacier White Metallic/6spd Manual/Sports Diff/Adaptive Damping Suspension/Black Napa Leather/19" Peelers/B&O Sound/MMI-Navi/Side Assist/Carbon Atlas Inlays
