Results 1 to 3 of 3
    Established Member Two Rings Alex44's Avatar
    Dec 02 2016
    1st - 2nd gear shift delay
    Just noticed this today as I don't drive the s4 hard that often anymore. Flooring it from a stop 1st to 2nd with that there perfect race car driver shifting it will go into 2nd gear like butter and stays there around 4000rpm, I put my foot back down pedal to metal and it just gives this 1-2 second delay then hauls ass in 2nd gear, what gives?
    Sep 09 2014
    Grand Rapids, Michigan
    After the car is in gear? You're fighting an electronic throttle and turbo spool. The electronic throttle has a small delay and even with stock k03 turbos they won't spool instantly.
    Dec 02 2016
    Well that was easy..I didn't expect it to be the clutch because it's in good condition and every other gear is fine. Seems It was just the tune giving way too much fuel after 1st gear shift and the engine would choke for a second giving me the delay
    Mods delete this please, she's running good again.
