    Veteran Member Four Rings MattboyR32's Avatar
    Nov 28 2006
    Orange County, CA, USA
    BC racing coil over install help
    Installing the bc racing cool overs. Do I need to take this rubber and metal thing off the top of the suspension (the thing that the control arms are bolted to)
    Cheers
    B7 RS4 6MT Daytona Grey
    JHM 2.75" catback non-res, piggie pipes, 034 transmission, engine mounts, strut mounts & end links, Apikol diff mount, Hotchkis adjustable rsb, Escort 9500i (HW), JHM lightweight rotors, JHM intake manifold spacers, BC Racing coilovers,
    RIP: B7 S4 DTM 6MT Dolphin Grey
    JHM Tune, Corsa Catback, Piggie Pipes, Bilstein PSS9, RS4 Reps, Blackvue Car Blackbox (HW), Escort 9500i (HW)
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    My ST kept needed them but they did not come with the top mount/hat. It looks like yours may replace that mount/bump stop seat. Let me know. I may consider those on my next S4.
    B6 S4, B8 A4, 8P A3, and something, something.
    Nov 28 2006
    yeah, otherwise it doesn't sit right. the top of the coilover is just slightly smaller than the metal bit of that top mount.
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    BC says you can do either.
    "The Rear Top Configuration is pressed-in rubber or the OEM Rear Top Configuration assembly is reused."
    from their website. I assume you can take the top mount off of the coilover and use the original strut bushing or just take the original strut bushing out and throw the BC coilover top on there.
    Let us know what your experience is with these coilovers! I'm curious to know. I like the idea of affordable dampening adjustable coilovers
    Nov 28 2006
    The problem is with taking the top mount off the coilover a is that the little adjustment dial disappears up into the original bushing. You can see the little dial and access hole in the pic. But the diameter of the bc mount is slightly too small and just sits awkwardly on the metal inner of the oem bushing. :(
