Results 1 to 6 of 6
    Veteran Member Three Rings piotrowr's Avatar
    Jul 18 2008
    Scottsdale
    Burning Oil Smell
    When the car is cold and running for the first few minutes, there is a distinct burning oil smell that comes into the cabin and present outside. But techs during the last oil change said everything looks fine, no leaks. Once warmed up it seems to go away. Any ideas?
    2010 A4 Avant Prestige - 19" Sport Package, Quartz Gray Metallic
    Active Member Two Rings dre731's Avatar
    Jan 08 2010
    brooklyn
    I get a gas smell. Not sure exactly what it is.
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Quote Originally Posted by dre731 View Post
    That is probably your cat. Catalysts do not work until they are very hot. Your ecu is in open loop for the 1st 30 or so seconds of the engine running and is running rich, combined with the cat not filtering out as many unburned combustion gases.
    2016 S3
    Instagram- @Thisisastickup
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by piotrowr View Post
    This is very odd, as the engine is simply not hot enough at this point to actually burn the oil. Could be built up blow by in
    The PCV/ oil seperator but that is unlikely.
    2016 S3
    Jan 08 2010
    brooklyn
    Quote Originally Posted by b6Hate4 View Post
    Should I expect the same thing with a performance exhaust?
    Oct 27 2010
    Norwood, MA.
    Yes, even more so.
    2016 S3
