    Veteran Member Three Rings snowboardgod's Avatar
    May 01 2014
    12’ TTRS, 20’ S5, 01’ S4 Avant
    Vermont
    Service due flashing in MMI b7 S4 NEED help
    Hi all
    2005.5 audi S4
    Lately my service in xxx days xxx miles is flashing on the center screen not only at start up but randomly while driving. I have searched and searched and cannot find any info anywhere where someone had this happen. Assuming it's a bug I will have to live with... but wanted to see if anyone can help. It will flash and go away... randomly cannot make it happen or predict it. Yes I have had my shop reset my service reminders w VAG com and it did not help... im lost.
    Veteran Member Three Rings IslandHydro's Avatar
    Nov 29 2008
    WA State
    have you read codes?
    B6 S4 Cabriolet
    Milltek exhaust w/ SW tips, H9 fogs (DRL), denison Ipod adapter.
    Debadged except the rings, TWM Leopard shift knob.
    TD Pro Race 1.2 Wheels, Continental Extreme Contact DWS.
    May 01 2014
    Vermont
    Not lately but last time no codes or any that Would make sense. Maybe my oil sensor is dirty or something I change the oil w Mobil one every 5k.... timing chain job done less then 10k ago.... no clue
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    What are the specific interval settings? Maybe one got accidentally changed to require service every 100 miles instead of 10,000, for example.
    http://www.ross-tech.com/vag-com/tou...creen.html#SRI
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    May 01 2014
    Vermont
    When I go to my buddies shop on Thursday I'm going to check, however it currently reads service due in 4700 miles 360 days on the dash. It shows up on startup then goes away with the OK message in green at the top.
    Then it will randomly flash service due in 4700 miles 360 days or whatever it is every few minutes as I'm driving. Sometimes it won't do it for a day or so other times it flashes 3 times in a minute... I cannot figure it out driving me insane!
