Haven't taken the car to the track, just a few spirited drives in the canyons.
All in all, the install wasn't terribly bad or much of a pain to do aside from trying to torque down the caliper bracket bolts to the spindle/hub assembly. I did purchase new bolt since they are stretch bolts. Found out that I really need to get a higher quality torque wrench with a smaller head. Car currently has 10,500 miles and the rear pads were worn about half way down compared next to the Hawk pad. Utilized all new brake hardware from Carlson part number 13489Q. Like the Carlson kit for 2 reasons: 1. Made in USA, and 2. The side that rests on the caliper bracket has a bonded ruberized coating much like the stock clips to reduce any noises and or squeals. Replaced the boots on the caliper bracket and regreased everything using Sil-Glyde for the caliper pins and brake pad sliding surfaces.
Used Carista APP to retract the parking brake and it worked flawlessly. For some reason it always throws a parking brake code that needs to be cleared out upon closing the parking brake module within the Carista App.
Pulling the car out of the garage, there were no funny noises or anything I could feel through the body. I started late in the day, so by the time I finished, it was around 10:45pm and the roads near my house are dead. Perfect time to bed in the brakes using Hawk's recommended method to a T. Went home, had a late night snack, cleaned up and then took it on the freeway to ensure there is no vibration or noises at highway speed.
First impressions are:
- Backing up, the brakes are not so darn sensitive. Hate that "on" & "off" feeling.
- Silent, no noises.
- Not sure about dust yet as my wheels are dirty.
- I can feel the rears actually grabbing now.
- Brakes feel more linear even though it's just the rear.
Will update when I get more miles on it.
Don't mind my dirty wheels.
