Results 1 to 2 of 2
    Oct 02 2006
    Wadsworth,OH
    : ECS Tuning :: NEW!! ECS Luft-Technik Intercooler System | Audi B8 A5 2.0T
    The ECS Luft-Technik Intercooler and Charge Pipe System was designed and engineered in-house to provide you with a direct bolt-on system to increase air flow, decrease restrictions, intake temps, and most importantly increase power!
    ECS Tuning's Luft-Technik Intercooler features a 21x9x3 aluminum bar and plate core with cast aluminum end tanks which uses factory mounting locations, so that no trimming or cutting is necessary. This makes installation completely reversible, creating a system to optimize performance and provide the clean look that Audi owners have come to expect.
    Key Features:
    • Reduced intake temperatures and air turbulence. (Up to 40% improved intercooler efficiency reduced intake temps by as much as
      65*F during solid state WOT loading.)
    • 52% reduced pressure drop
    • Increased air flow capacity
    • Gains of up to 13 WHP and 10 Ft-Lbs WTQ over APR Stage 1
    • Cast aluminum intercooler end tanks
    • Bar and plate design intercooler core
    • 2.50" diameter intake tract
    • 4-ply silicone straight/hump couplers
    • Aluminum tubing powder coated in a tough wrinkle black finish
    • OEM like bracket secures the throttle pipe in place
    • CNC machined MAP flange welded to factory position
    • Eliminates the factory noise pipe
    • Includes all stainless steel t-bolt clamps
    • Easy and direct replacement upgraded system
    Gains of up to 13 WHP and 10 Ft-Lbs!
    Fits:
    Audi B8 A4 2.0T 2009-2016
    Audi B8 A5 2.0T 2008-2016
    Audi B8 Allroad 2.0T 2013-2016
    Be sure to check out our ----> Installation PDF <-----
    Jason
    Oct 02 2006
    Wadsworth,OH
