Results 1 to 16 of 16
    Senior Member Three Rings wriscolf's Avatar
    Jul 10 2016
    1993 Nissan 240sx Convertible with Silvia Front
    P0171 and p0507, which route should i take?
    So while cruising the CEL came on. Codes were p0171 and p0507. I did my research in multiple sites on Google and AZ
    So from what I gathered 3 things can cause this:
    1) PCV
    2) vacuum leak
    3) Intake motor flap.
    So now with this I am not sure which route should i take to trouble shoot. I checked for any tips and such on vacuum line as much as I could (I was dropping my brother off an hour and half or so away and didn’t have much tools). And all vacuum lines feel fine. So now we have PCV and Intake motor flap.
    Idea I have to fix PCV is to just get a catch can. I am scared that new PCV will give the issues of slug and such on valves, is this recommended? Does the revised PCV fix all issues that old one had? I am not trying to do crazy numbers on track or anything. Just want a reliable car with some pep (Sig has my mods and I’m probably staying close to that forever)
    Intake motor flap: replace it.
    Now that i know my options i read on here that this was a recall, now my question to the expert is that if it’s a recall wouldn’t Audi have to replace it for free? Or is there still depending on that 120k mile extended warranty.
    Thanks
    2007 Audi A4 S-Line Titanium Edition/Phantom Black/Magnaflow Exhaust/APR Stage 1/APR Carbonio Intake/Lots of Headaches/
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    12 Taco, 13 Ex, 16 Civic EX, 15 JKUR
    Refresh my memory....what do those codes mean? They look familiar but haven't memorized them... Guess I could google them but don't have that much free time to burn at the moment.
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
    Feb 16 2015
    I had a P0171 on friday due to blowing off my boost gauge line (caused a vacuum leak). So that might be a good place to look.
    I also have a replacement intake motor flap off my spare engine in you need.
    2005.5 Dolphin Grey A4 Avant 2.0T Tip / Premium / Lighting / Cold Weather / Sport
    RAI K0R-GT / JHM K04 Tune / 034 HFC -> B7 S4 CB/ ST Coilovers / Hyperco 8" 750 Lb / 034 RSB / 18Z / 15% Tint / S-Line Paddle MFSW / 034 St M and T Mounts / GEN II RNSE
    Senior Member Two Rings DenverAudiInnie's Avatar
    Aug 20 2016
    I had the same codes. I took the manifold off to do a carbon clean and to make sure the flaps weren't sticking....as I was pulling the manifold off, a vacuum line snapped. That was not visible to the naked eye until I pulled the manifold. I cleaned the PCV and replaced the brittle line with the braided style. Codes went away and never came back. Your scenario may be completely different, but I lucked out.
    Sent from my SM-N920T using Audizine mobile app
    2005.5 Audi B7 A4 Quattro Prestige in Dolphin Grey & RS5 Rims
    Jul 10 2016
    Quote Originally Posted by mcpcartier View Post
    p0171: Motor running too Lean (something like that)
    p0507: rpm too high at idle (something like that)
    These are off the top of my head but pretty much its what it means. i cant get the exact name. Dont want to get caught on a forum while at work.
    - - - Updated - - -
    Quote Originally Posted by gonemtbiking View Post
    No boost guage in yet (funny how i just received mine on saturday in the mail. I will let you know on the intake motor flap. Actually. let me know how much shipped to 10456. Used? No code?
    Jul 10 2016
    Quote Originally Posted by DenverAudiInnie View Post
    Yeah that sounds lucky, you kinda got everything done in one go. Idk if i should start at PCV or Motor flap. I think im going motor flap since i did get a soft code before i erased it to see if it came back. i dont remember the code.
    Oct 24 2015
    Perth, WA
    Replace PCV and conduct an adaptation on the manifold flap runner.
    My respray thread
    Jul 10 2016
    Quote Originally Posted by Okedokey View Post
    Would a Catch Can be a bad idea? for an overall preventative upgrade? Or its not really that worth it?
    Jul 10 2016
    So I just did a pcv check and yup, can't pull up the oil cap when car is on.
    So now my question is whether or not I should just get a catch can or if I should just replace with new revision.
    Sent from my SM-G935T using Tapatalk
    Aug 20 2016
    Quote Originally Posted by wriscolf View Post
    PVC it is!!!
    Jul 10 2016
    PVC it is!!!
    Yup, just deciding if catch can is better long term vs pvc valve. I'm happy because I get to put my boost Guage at the same time as this lol.
    Jun 08 2007
    I have the same code
    Went to my mechanic and narrow it down to pcv and the idle air control valve. But since b7's idle air control valve is attached to the throttle body, I have to change the throttle body. I read somewhere that I have to reset the throttle body with a vag com, is this true?
    Jul 10 2016
    Quote Originally Posted by A-List View Post
    From the research ive done, you probably do. But i am not sure if i am confusing that with intake motor flap. You might be able to do it by a pedal trick or what not. I am not sure. Hopefully someone can answer that. How much were you quoted/paid for the throttle body? Just so i know my future expensive if its not only PCV.
    Jul 10 2016
    Just to close the loop for anyone searching, I changed the PCV this weekend and clear the codes. Did a short test run and drove to work today. Checked for codes and car is fine. PCV was the cause of both of these codes together in my case. Good luck. I will update if that changes.
    Junior Member Two Rings
    Nov 02 2018
    greenwich
    I have a similar issue with same codes and wondering where to post?
    Nov 02 2018
    greenwich
    Quote Originally Posted by Stretch625 View Post
    Oil cap comes off without a struggle but replaced the PCV anyway. No joy.
