Results 1 to 25 of 25
Thread: engine question
    May 14 2012
    new jersey
    engine question
    I have a 2000 s4 manual, I am thinking of getting a lower mileage engine to swap into my car (engine would be from a 2001.5 auto). My question is what are the differences between the automatic and manual engines? I know the autos use the sai system which would need to be blocked off, and I know the autos use a flex plate, but I would throw that in the garbage cause I have all the manual stuff (obviously). other then that what else would I have to worry about? any input is appreciated. I have googled for info but I am coming up with little info. just basically the sai system.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    What's wrong with your engine?
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Aug 06 2016
    colorado
    it would just bolt right up.
    May 14 2012
    new jersey
    Thanks spacecraft.
    CELison nothing really just high mileage 150k. I know that's not that high, but I came across 2 engines one with 91k and another with 81k that are relatively cheap at 400 and 600. Both are supposedly in good shape
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    If it ain't broke, don't fix it. There are a few owners with 300k+ engines still up and going. You're asking for trouble.
    Feb 23 2010
    Emmaus Pa
    I pulled my engine apart at 165k and could still see the cross hatch in the cylinders clear as day. There's several running strong at 300K + miles.
    B9 S4- EPL/AWE
    May 08 2016
    Manhattan
    I would run that engine into the ground. Mine has 170k stage 3 and runs fine so I wouldn't worry that much. I bought a spare and started building it up to handle more power then will swap it when ready no rush. Unless your doing that I would keep the one you got in the car.
    Veteran Member Four Rings ReggieNoble's Avatar
    Dec 17 2016
    B5 S4 Avant
    Fl
    I believe there is a spacer or a ring on the output shaft on autos that would need to be heated and removed
    Sent from my LG-D850 using Audizine mobile app
    Dec 17 2016
    B5 S4 Avant
    Fl
    Dec 17 2016
    B5 S4 Avant
    Fl
    Sorry meant spacer on crankshaft will need to be removed. # 15 in the pic
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    I wouldn't worry about the mileage. I have 245k on mine. If you are dead set on swapping engines the auto motors have secondary air so you will need to block the combo valve ports in the heads
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    Swapping an engine in for a 60k mileage diference would be a huge waste of time. Not to mention you know how your engine was maintained. I'm sure several others will agree with me.
    Aug 04 2013
    Pennsylvania
    Definitely agree with everyone saying waste of time. I've been stage 3 for the past 50k, no issues. I'm at 185k now.
    I have a BEL on a stand waiting for internals and I'm hoping I can have that ready with 770's maybe as a 200k present for my car lol
    I'm like a tree. I'm all root
    Aug 06 2008
    Canadia
    Id rather have a taken care of high milage engine than a mystery maintenance low millage.
    As the saying goes, its the devil you know vs the devil you dont know.
    Veteran Member Four Rings slowSfaux's Avatar
    Apr 26 2015
    Phoenix, AZ
    Another vote for this being a waste of time. Swapping for lower mileage is only advisable if the current engine has serious issues. If it runs like it should, doesn't consume coolant, doesn't burn excess oil, run it until it breaks.
    Veteran Member Three Rings insomniacxp1's Avatar
    May 10 2010
    01.5 B5 S4
    Rochester, NY
    205k stage 3 f21's @ 25 lbs and loving life, keep the engine in man.
    01.5 Imola S4. Stage 3 F21's/To much to list
    May 14 2012
    new jersey
    Thanks for the input guys. I was just tossing around the idea of either freshing up my motor or getting a lower mileage motor. I'm pulling my motor and trans to put in a new clutch, rebuild the trans, and do the rear main seal.
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    I agree with everyone else here. If you're really concerned, do a compression test and go from there. Save the $ for the hundred dollars worth of rubber hoses you'll eventually need, lol.
    Apr 07 2011
    Home of the mighty beaver
    the blocks are not the issue. The heads take a beating. two sets of 2.7T heads with various exhaust valve issues, pitting, burning, leaking.... blah.
    I broke two motors before I had enough stuff to build one good one with 2.8 heads with 2.7exhaust valves.
    Trouble is these cars have passed from new, to enthusiasts, to broke-ass idiots that don't maintain their cars.
    Clean engines are going to rapidly become a hot commodity.. I think this latest build will be my last spin of the wheel on this platform. Time to move to something newer.
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by S4James View Post
    This is all true. You'll come back though. I played in the b8 scene for a while then came back.
    B9 S4- EPL/AWE
    Aug 24 2014
    Newport Beach, CA
    One more vote for keeping your engine, mine had a very hard life before my ownership and finally died at 450+whp at 305,400 miles. The cylinder walls still looked OK even after all those miles, as James said the heads are the part that tend to degrade i.e. valve seal stems can start leaking, etc.
    FWIW after diagnosing, we concluded that the thing that likely killed that engine was a broken driver's side primary o2 sensor wire in the engine harness that decided to sever while I was at WOT.
    2024 M3 Comp xDrive
    Established Member Two Rings paul61's Avatar
    Mar 11 2013
    Waterloo, Ontario, Canada
    Quote Originally Posted by Corradovolksb View Post
    575K here. Runs great
    B6-S4 6M, Black on Black
    B5-S4 6M, Black on Black
    Established Member Two Rings Daveb5s4's Avatar
    Jul 09 2016
    Coquitlam, Canada
    Wow!! 575k impressive.
    Aug 24 2014
    Newport Beach, CA
    Paul, I'm assuming that's 575K kilometers right?
    2024 M3 Comp xDrive
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    Maybe 575KitKats?
