Results 1 to 8 of 8
    Oct 25 2016
    Explanation of these codes when clicking the 'check' button
    When the car is started and I press the "check" button, it runs threw the various checks but I noticed some of them have a cross on the icons.
    From what I understood from the manual, if there is a X on the icon that means the sensor could be bad?
    Note: These codes only display when I press the check button.
    Established Member Two Rings Sally4's Avatar
    Apr 24 2016
    Mitsubishi Evo GSR
    Placentia, Ca
    Oh man i wish i can help you. Doesnt it usually dash checks are for electrical circuit issues. Check your rear brake lights or maybe lighting issues might be one of the bulb going off soon
    bborces
    Senior Member Two Rings Skeee's Avatar
    Nov 19 2008
    2008 Audi RS4, 1998 Gti VRT, 2003 Audi RS6, 2004 VW R32
    Washington
    have you scan for codes? also have you performed any visual inspection like, check oil fluid levels, coolant level and walk around the car to see the obvious if any of your lights are out?
    Dirtbag
    Nov 19 2008
    Washington
    Quote Originally Posted by Skeee View Post
    if everything looks okay, then i highly suggest to have a professional or if you are mechanically inclined to take a deeper look at the situation. Good luck
    Dirtbag
    Oct 25 2016
    When your car is running and in park, and you press the 'check' button, what happens?
    It cycles through all the checks for me, and then at the end it says in green "OK". But the oil pressure icon has a cross mark in the bulb icon....
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    when you press the check button , it goes through a checklist of things(lightbulbs/oil/coolant etc.)
    it should give the green OK afterwards
    if any icon stays lit, you have something to check
    Oct 25 2016
    Yes I get the OK green at the end.
    Quote Originally Posted by jakeoboy67 View Post
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Quote Originally Posted by dualquad View Post
    Then everything is OK.. Nothing to check further
    Sent from my SM-N900V using Tapatalk
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
